help, slave cylinder!
Old 06-19-2009, 01:39 PM
wbthornton88's Avatar
Ok, so after replacing my clutch, my dad went and pumped the clutch pedal before I had the slave cylinder bolted back up. The spring and all the other shot out in one piece along with alot of fluid. I put the cylinder back together inserting the spring first and pushing it in with my finger. After bolting everything back up, I have no clutch. I'm trying to bleed it but I just get a little fluid dripping and when I retighten and pump the clutch it gets no pressure built up.
Old 06-19-2009, 01:53 PM
Staff
DeathCougar's Avatar
The seal might have shot out along with it. Find that seal, or get a new slave cylinder.
Old 06-19-2009, 01:55 PM
waskillywabbit's Avatar
New slave cylinder is pretty cheap. Just replace it.
Takes about 5 to 6 cyles of "pumping" the pedal to get a nice firm clutch pedal.
Old 06-19-2009, 02:51 PM
ok well I got that fixed I just had to bleed the clutch at the master cylinder. Now when i start the truck and engage the clutch, the gears won't shift as if I don't have the clutch fully engaged. When I start the truck in first it jumps as if the clutch is already letting out?
Old 06-20-2009, 02:04 AM
wyoming9's Avatar
You did remember to put the throw out bearing back in .
You might have to adjust the rod on the master cylinder to make up for the size difference in the new clutch
camel_65@hotmail.com
10-03-2018 06:11 AM
mxdw88
09-20-2015 03:13 AM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
scheuvront1993
09-17-2015 06:17 PM
Quick Reply: help, slave cylinder!
