help....replacing fuel filter on 2nd gen
so this morning im trying to replace my fuel filter.. just curious how much gas is going to hit me in the face once i disconnect the lines on either side of the old filter.
I was planning on opening my gastank to take the pressure down a little...
anyone have any other suggestions/tips/hints for me ?
Thanks
Thanks
Thanks
Thanks
the cross member is connected to the transfercase or transmission.....
help.... i cant get access to the second nut with out removing the cross member,... but im worried the transfercase or transmission wont be supported... plus there are 3 hard to get at bolts to disconect the crossmember from it...
any pointers??
any pointers??
Unbolt it from both sides. Let it droop down (it'll be fine). The crossmember will flex enough from side to side to get your hands in there. You'll need a jack to lift it back up to reconnect it.
i just went to canadian tire and they did it for $30 canucks and i am free of any worries. Its hard to do it for our toyota here in canada coz of the rust!
I tried doing it but i gave up because i will surely break something before i will be able to replace it.
btw, i bought the fuel filter from the dealership and they want to charge me $80.00 to install so i shopped around.
thanks for the tips....but alas after droping the cross member and fighting with the last nut for 3/4 of an hour... i finally gave up and had to bolt back everything....
thanks for the tips....but alas after fighting with the last nut for 3/4 of an hour... i finally gave up and had to bolt back everything....
which way did you go at it .... if its the 22re im a big guy with big hands and managed to get everything off. i took off the tire and a little panel under the fender and with difficulty go them. if not the 22re then i dunno!
I did not remove my crossmember when I changed mine. Though I did end up snapping the front fuel line because the nut had rounded out.But the new line was only $35 at the dealership and was very easy to replace.
pyramid
07-30-2015 10:05 AM
