Help! one foot on the brake and the other on the gas
Old 10-06-2009, 10:34 AM
rocketbud's Avatar
Hi, New here hope to get some helpful thoughts on this, bought a used 90 4runner with a rod knocking 3.0/ and A/T, I pulled the engine (which was a rebuild previous owner had put in) and I put in a new crank, rod & main bearings, driven about 100 miles since runs great, then yesterday I started it up started to leave the drive (20 % incline) and it was like I had one foot on the brake and the other on the gas (or maybe like it was in OD instead of 1st gear ?) I backed up and was just fine, tried forward, and same thing like I had my foot on the brake (park brake was not on) parked 5 minutes started again and everything was fine drove 20 miles (I'm afraid this is what fried the bottom end on the previous owner?) anybody have this prob before?
Old 10-06-2009, 10:40 AM
Lumpy's Avatar
Sounds like the tranny maybe? Something got plugged?
Old 10-06-2009, 10:43 AM
Innervision's Avatar
If you have not already, check the tranny fluid it may be low. Mine did the same I had to keep topping it off for about a week until it got all the air out of the system. Now it runs fine.
Old 10-06-2009, 11:04 AM
sb5walker's Avatar
I'm thinking tranny/fluid, too, maybe a torque converter issue?
But the next time it happens, try putting in neutral to see if the brakes really are hung up.
Old 10-06-2009, 11:20 AM
rocketbud's Avatar
I just checked the trans-fluid (engine and trans stone cold) and I see 2 notches at the bottom that says "cool" and 2 notches farther up the stick for the "Hot" well this thing is showing fluid up the stick about 1" past the hot marks when it is stone cold, basically showing fluid for the first 4 inches of the stick, could someone have put in to much fluid and would it cause a problem like this ? (keep in mind I have owned this for less then 150 miles)
Old 10-06-2009, 11:24 AM
Junkers88's Avatar
I don't know a lot about auto's but I'd recommend draining all the fluid out and putting in the correct amount of new stuff. Might not be a bad idea to change the filter while you're in there. (autos do have a filter in them don't they?)
Old 10-06-2009, 11:29 AM
woodendude's Avatar
Quite possibly a stupid question but it was running when you checked the tranny oil right? If so drain and refill as suggested above.
Old 10-06-2009, 11:38 AM
sb5walker's Avatar
Overfilling an auto tranny can damage seals and cause the fluid to become foamy, which will cause shifting/power transmission problems - exactly like you described. So, yes, drain and refill to proper level with a good Dexron fluid.
Old 10-06-2009, 11:53 AM
Lumpy's Avatar
Old 10-06-2009, 12:01 PM
rocketbud's Avatar
Thanks for all the replies guy's....... I will take your advice and change fluid and filter, just thought after seeing all the dang wires attached to this trans that there might have been some sort of solenoid or something that was a cause for this (not allowing it to drop into 1st gear.
I did get a little impatient on my stick reading, guess I should have waited at least 40sec. to take the reading which did go down...... ooop's
Old 10-06-2009, 01:31 PM
TORTIS's Avatar
Sounds like Sammy Hagar"s "I can't drive 55".
Sorry couldn't help myself, and yes I am showing my age!
Drain a little out and see if it helps.
Old 10-07-2009, 09:07 AM
putneysmachine's Avatar
I've recently ran into a couple of faulty torque converter lock up solenoids. When they go south, it leaves the torque converter locked and doesn't allow the converter to "slip" causing it to feel like you are starting out in the wrong gear.
Grab a wiring diagram / component locator page from an online manual and check the wiring / harness that goes to the solenoid. Check for any cracks, cuts, abrasions in the wire...etc. Also check the pins at the solenoid / harness connector for dirt and such since it is exposed to the elements.
Old 10-07-2009, 09:52 AM
toyota4x4907's Avatar
Exactly what I was thinking. "One foot on the brake. and one on the gas *OH!* Theres too much traffic, I can't pass.
I'm not old though..
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
skoti89
09-11-2015 07:46 AM
colasurdo
07-17-2015 11:29 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Help! one foot on the brake and the other on the gas
