HELP!!!!! No Power on low end and Hard starts in COLD weather.
Old 12-09-2009, 11:57 AM
payne222002's Avatar
3VZE with about 173000 miles. starts right up and runs fine when idling. Low to mid range power is really lacking whether under load or just with a normal rev. Has anyone had this problem? New fuel filter, plug wires, new cat and exhaust, and ran heet through the system. I have a few thoughts but want to see if yours is the same as mine. thanks for looking and helping.
Old 12-09-2009, 06:11 PM
yoterr's Avatar
i think theres a cold start injector just like on a 22r?? i THINK, but if its malfunctioning it wont give you that rich condition the motor needs when cold, runs good when warm right?
Old 12-09-2009, 07:18 PM
No even when it's warm it still seems to lag on the low end once the RPMs are up it runs great. It is so bad I can't even run on the highway in 5th gear and if uphill then I can't run in 4th gear either. Not enough power. If it did as you explained I would lean toward the cold start injector but it does it all the time. The hard to start when cold seems to be a result of the main problem. At least those are my thoughts. Please if anyone has had this happen or knows the issue HELP!!!! Thanks for your reply!
Old 12-10-2009, 05:52 PM
The heck with it.
I believe I should just do a swap. 1UZ or the 5VZ? What do you guys think?
Old 12-10-2009, 06:40 PM
Tracey98277's Avatar
5VZ would be the best choice for power and $$$
Old 12-10-2009, 07:54 PM
U think so
I can get the 1UZ for about 400 as apposed to the 5VZE, I can get it for about 1000. They seem to be more, I guess just because of their popularity. I know in the long run the 1UZ would be a little more but V8 power is pretty nice
Old 12-10-2009, 09:52 PM
ahhh... i guess i'm not very familiar with the 1UZ.... in fact... i don't know anything about it lol... RESEARCH TIME FOR ME!
Old 12-10-2009, 09:56 PM
oh... its that lexus quad cam motor... those things are beast. GO FOR IT. i think the next time my 3vze dies i will do a 1UZ swap.
Team420
01-12-2021 04:57 PM
Cesarl74
04-23-2016 06:07 PM
Ichneumon
09-27-2015 04:21 PM
jmc88runner
06-18-2015 03:39 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: HELP!!!!! No Power on low end and Hard starts in COLD weather.
