HELP...New engine running crappy
Old 07-24-2011, 01:38 PM
MrHunterman12's Avatar
Hey I just put in a new 22RE engine in my truck. Adjusted everything (timing, lifters, etc) and broke it in according to the instructions for the pre-start (run 20-30min and readjust).
So I went to take it for the test dive and everything was going great until I got about .5 miles down the hill and it started running really rough (almost sounding like it was miss-firing). Turned around and headed home, recheck the timing, vacuum hoses, plugs wires and still its not working right.
I also got check engine light 22 (water temp sensor) but I wouldn't think that would cause it to run crappy like that would it?
Any ideas? I am stumped...
Old 07-24-2011, 01:45 PM
xxxtreme22r's Avatar
if the water temp sensor is not covered by water and/or faulty, it will affect how the engine runs. I bet you have an air bubble in the coolant system.
Old 07-24-2011, 01:54 PM
fork's Avatar
yes it definitely can. the connector on mine broke off and it started to run like total garbage until i got home and realized it was broken. got a new one and problem solved
Old 07-24-2011, 02:01 PM
tim a.'s Avatar
lifters?.....lifters?oh well,did distributor loosen up?timing checked with ecm jumper?checked valve lash?could be a coolant bubble,but that would go away after adding coolant.But Im no xpert...
Old 07-24-2011, 08:17 PM
Which sensor should I replace?
Old 07-25-2011, 06:44 PM
More help please :)
Alright...After investigating after work I found that the green sensor had a broken wire. I fixed it and the light went off.
NEW PROBLEM
It is still running like crap There is no check engine light and it still runs rough like it is missing. My Dad and I took off one of the fuel injector plug and started it up and it ran the same (WTF), then put that back on and took off the second one and still ran the same (rough).
I am about ready to just take the damn thing down to Yota and have them do the pocket draining test $$$ lol.
I am super stumped...Any ideas?
Old 07-25-2011, 07:16 PM
Hukill702's Avatar
Start with the basics, is every cylinder getting spark/fuel. check and double check all connections, cuz as you found out with the temp sensor; a bad connection is not always easy to spot. Also i was wandering if you got a crate motor or rebuild. I only ask becouse a friend of mine had the same problem with his heep after a fresh rebuild and the problem ended up being that the machine shope did not clean out the fine metal dust left inside the head after machining. We found this problem very easily by draining the engine oil and running a magnet threw it.
Old 07-26-2011, 04:43 PM
Still nothing I feel like this could be a simple fix lol...
Any more ideas my fellow Yotatech peps?
Old 07-26-2011, 04:49 PM
I will make a video and post it later...maybe that will help?
Old 07-26-2011, 05:37 PM
Does this help at all?
http://www.youtube.com/watch?v=VxQe5...yer_detailpage
Old 07-26-2011, 05:50 PM
what did you set the ignition timing to? You remembered to use the jumper right?
Old 07-26-2011, 05:54 PM
Its set to 5 degrees BTDC and yes I did use the jumper...
Old 07-26-2011, 06:50 PM
Anything?
Sorry I am trying to get this running soon so I can give my Dad his Yota truck back...
Old 07-26-2011, 06:53 PM
start pulling plug wires. one at a time, see if it runs the same with one of them taken off.
Old 07-26-2011, 07:12 PM
It bogs down when I remove one and I did it to all 4 and got the same results...Man this is frustrating :/
Old 07-27-2011, 02:14 PM
tim a.'s Avatar
.You need a vac gauge from harbor freight,or any tool store,hooked up to a manifold vacuum source.Kind of looks like a vac leak,but the way its shuttering and dying Im not sure.You really need to recheck your vac line routing.The wrong line plugged into the wrong spot is what I am thinking,but the vac gauge will show you whats going on inside engine.
Old 07-27-2011, 04:42 PM
skypilot's Avatar
Have you checked fireing order? One wire off will do that too.
Old 07-27-2011, 04:58 PM
It's just weird because it was running just fine before .5 mile down the road...
Old 07-27-2011, 05:08 PM
skypilot's Avatar
Is it just possible to have skipped a tooth on the timing chain? Perhaps pull the vavle cover off and walk the engine over. watch the valve train move, maybe a rocker broke?
Old 07-27-2011, 06:34 PM
fork's Avatar
you sure the distributor isnt off by a tooth?
x2 check the valve lash and in doing so make sure the chain didnt jump
have you checked the TPS adjustment? if the TPS is out it will cause strange things to happen too
Quick Reply: HELP...New engine running crappy
