YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 11-17-2007, 02:41 PM   #1 (permalink)
Help me Identify this...
I need to know what goes in there, color, what to where? where to what? Bought the truck like that, first yota truck also, clueless... so help guys, i know for sure my signal lights don't work, if i can get that to work, then i can be on the road no problems.
thanx in advance
oh yeah... forgot to mention, it's an 87 4x4 yota truck, last owner changed the dash and cluster also.
Sactown4x4 is offline
Sponsored Links
To remove this ad, register today!
Old 11-17-2007, 02:53 PM   #2 (permalink)
Shoua's Avatar
I believe only certain connectors will fit in those, if anything even goes in those. Looks like you're missing a few fuses as well?
Shoua is offline
Old 11-17-2007, 02:54 PM   #3 (permalink)
SCYOTA's Avatar
It should only fit on one of the male connections. Look at the terminals on the plug and match it up with the terminals on the fuse box. It might be that they wont fit up at all if the cluster was changed but I don't know for sure.
__________________
"WHY DO DRIVE THROUGH ATM'S HAVE BRAILLE?"
SCYOTA is offline
Old 11-17-2007, 03:36 PM   #4 (permalink)
Remove the mounting bolt(s) and look at the back of the fuse box. That may tell you if they are even wired/needed. If you have the lid, that should tell you what the fuses are for. Trace the wires on the back of the box.
Hope this helps.
billmaness is offline
Old 11-17-2007, 05:50 PM   #5 (permalink)
yota4runna's Avatar
Here's what's in my '87 4Runner:
The black device is the turn signal flasher, the silver can to its right is the taillight relay, and the silver can below it is the EFI main relay. Yours must be carbureted, so this would empty on yours.
This is the fuse cover, showing what the fuses go where:
The numbers are 81980-16010 on the T/S flasher and 90987-01003 on the taillight relay:
Hope this helps.
yota4runna is offline
Old 11-17-2007, 06:36 PM   #6 (permalink)
thanx guys
You guys ROCK!!!!!!!!!!
THANK YOU
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Help identify this? BeachRNR 95.5-2004 Tacomas & 96-2002 4Runners 1 04-28-2007 05:59 PM
Identify this paint! subgenius 95.5-2004 Tacomas & 96-2002 4Runners 20 07-29-2006 01:08 PM
Help me identify this cluster rdlsz24 84-85 Trucks & 4Runners 21 05-13-2006 02:30 PM
Identify these wheels 83beater Pre 84 Trucks 15 04-10-2006 10:25 PM
Help identify please CANADA4RNR 86-95 Trucks & 4Runners 9 02-09-2006 12:18 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
