help im stuck
Old 05-18-2008, 02:07 PM
neptune's Avatar
help im stuck
i recently attempted to replace my headgaskets on her 95 4runner. i got the heads rebuilt, and put back on but i couldnt get the exaust cross over pipe on. Ii accidently pulled the moter from the trans. now i cant get the moter back on the input shaft. i can get it back in, all except the last half inch. i dont know if i am alingning somthing wrong, or what but i am pretty exausted and about to give up for today. any tips or info would be greatly app,thanks
Old 05-18-2008, 04:04 PM
Elvota's Avatar
Tip 1: Welcome to YT.
Tip 2: I'll move this thread to the correct section so you'll get some responses.
Even more info here:
https://www.yotatech.com/forums/f121/welcome-yt-142459/
Old 05-18-2008, 04:13 PM
ahickman's Avatar
manual or auto?
Old 05-18-2008, 04:32 PM
Seacoast's Avatar
Can you even get any of the bolts started? Are there dowel pins (short tubes or pegs about the size of a bolt) on the mating surface of the engine or trans? If so make sure they are fitting into holes in the other part. On some engines, frankly, the easiest way to get things aligned is to get some extra bolts, cut the heads off, bevel the cut ends, and use them as guide pins.
Sometimes you have to get the motor mounts and trans mounts pretty loose and have one person wiggle the engine around while the other lies underneath and moves the trans. On the last engine swap I did, one of us had to use a two by four as a pry bar to move the engine around!
If you can get the bolts in but just can't slide the parts together, make sure there's nothing caught between them. Also try rotating the engine or trans by hand, maybe the shaft isn't really engaging as well as you think.
Old 05-18-2008, 08:38 PM
bigt's Avatar
i cant seem to get my tranny seprated from my engine NO FAIR.... i have undone 10 bolts from the bellhousing... the starter is still in place its on the tranny jack level and no level i wiggle and wiggle tranfser case and it move the engine and tranny even with a jack under the engine
dont worry we will get there tommorow man!
Old 05-18-2008, 09:23 PM
Elvota's Avatar
Originally Posted by bigt
the starter is still in place....
Make sure there are no bolts from the starter to the bell housing. I am 90% sure that starter has to be removed to separate the housing.
I am 10% sure I am wrong.
Old 05-19-2008, 12:32 PM
Jay351's Avatar
The starter doesnt need to be removed, but its bolts do. IIRC at least one bolt that secures the starter goes through the tranny bellhousing into the motor.
Redeth005
06-28-2018 08:16 PM
rubrsidedwn
07-07-2016 07:28 PM
spiewaker
12-16-2015 01:10 PM
BK2TFUTURE
10-11-2015 08:42 PM
Obmi
09-24-2015 08:10 AM
Quick Reply: help im stuck
