Help with ground location on 3.0
Old 01-09-2011, 12:53 PM
freshspecbluegt's Avatar
Hi all,
Nearing the end of my engine overhaul but I can't find a picture of where this ground strap connects to.
Does it bolt up to the other ground on the rear of the passenger side head or is there a separate place for it.
If you have a picture I would appreciate it.
Thanks
Old 01-09-2011, 01:06 PM
justin_4runner's Avatar
it goes on the top plentum after u install it. there is a location on the back side towards the fire wall it goes to.
Old 01-09-2011, 01:45 PM
theMonch's Avatar
Don't quote me on this, buit I'm pretty sure it actually is bolted to the passenger side head not the intake plenum. I have attached a pict of were I thought it was. This was after I just pulled my 3.0 last summer. The bolt hole circled in red is the one I believe.
Old 01-09-2011, 02:14 PM
some drunk guy's Avatar
X2 bolts to the top Intake plentum on the back
camo31_10.50's Avatar
does it really Matter? ROFL!
as long as everything is bolted up correctly, you could put it anywhere on the motor.
mine is on the "CAP" that's on the back of the passenger side head, the "CAP" that covers the cam..where the fuel line is bolted down.
i also had the exact same ground bolted to my upper intake manifold, and never had any problems at either place.
Old 01-09-2011, 08:48 PM
theMonch's Avatar
True, it really shouldn't matter as long as it is a good clean connection from motor to firewall. Mine was on that bolt from the head, it sounds like a few others have had it on the plenum.
Old 01-09-2011, 08:55 PM
az_eaglescout_pilot's Avatar
mine is bolted to the intake manifold on the back towards the firewall
Old 01-09-2011, 10:01 PM
Guardian_Saint's Avatar
hmmm. Mine is bolt on top of the air chamber. I don't know if aluminum should be use?
Old 01-09-2011, 10:27 PM
ZARTT's Avatar
Ground Connection
The factory bolted it to the top of the air intake plenum.
Old 01-10-2011, 12:46 PM
Thanks for the input guys. Hoping to get this thing running in the next week or so.
Old 01-10-2011, 12:48 PM
Engine bay looks like you could fry an egg on it friend, keep up the good work! it's worth it in the end!
SubiKing
08-21-2021 03:57 AM
tobylab
01-18-2016 07:06 PM
gmonnie123
07-26-2015 02:44 PM
jetspeedz
07-13-2015 09:32 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: Help with ground location on 3.0
