Help with engine gaskets!
I'm gonna guess 1 is the oil pump, 2 and 3 are for throttle body (depending on which engine you have), 4 is for the plenum-to-intake manifold. Remember that you "should" have gaskets left over; a decent gasket set will cover several different flavors of engine.
As to the rest, I'm not sure I could guess them even if I could tell the size. You may have to compare them to the gaskets you took off.
09-04-2015 09:27 AM
