HELP! Cannot identify part that is leaking
Old 06-26-2015, 12:58 PM
Lybrium's Avatar
Hi! I have a 3vze (92ext) part that is leaking what looks like brake fluid. Problem is, i cannot figure out what this part actually is. It is an Aisin component right below the battery. there are lines going to the rear drum brakes from it, and also power steering lines into and out of it. Thanks for the help.
Old 06-26-2015, 01:12 PM
Robert m's Avatar
Its the ABS controller for the rear wheels
Old 06-26-2015, 01:14 PM
wyoming9's Avatar
Red face
Toyota calls it the Actuator for the rear ABS .
It gets a signal from the ECU.
Old 06-26-2015, 01:15 PM
Lybrium's Avatar
Ahh! abs actuator, thank you. It's leaking around one of the brake line connections. is there a seal or o-ring in there?
Old 06-26-2015, 04:47 PM
jbtvt's Avatar
Flare fitting. try tightening it up with a 10mm.
Old 06-27-2015, 06:17 AM
Marc's Avatar
Is your brake fluid level going down in the reservoir?
It might be power steering fluid that is leaking above the brake lines.
Brake line fittings don't normally start leaking.
Old 06-27-2015, 06:42 AM
wyoming9's Avatar
Red face
The lines most often just break!!
Old 06-27-2015, 12:43 PM
Lybrium's Avatar
The reservoir has not visually gone down yet, but it's a small slow leak. It's not the psp above dripping down, it's leaking right out of one of the flared fittings for the rear brakes, right at the seating on the actuator. Tried tightening, but it's tight enough that i can't budge it. It looks like the lines were replaced not too long ago, they are in good shape, can one just replace the fitting?
Old 06-27-2015, 06:59 PM
jbtvt's Avatar
I wouldn't touch it till the reservoir starts dropping. If the line is split or fitting is galled you can buy line and a small pipe cutter type tool to cut, bend your own, and form a *double* flare on each end with the correct tool. Doing this way you can splice in a new line wherever and mate it to the existing with a union. You can buy an entire replacement line also. Not recommended to splice using a compression fitting at brake PSI, also it's illegal. If brakes failed, you hit somebody and they saw that on your lines you would be in deep...trouble.
Old 06-28-2015, 01:12 PM
Lybrium's Avatar
Well, I think I will touch it sooner rather than later. If I press on the brakes the fluid comes out quite freely. I would rather get it fixed up now than wait until it becomes a bigger problem. Also, it seems my steering tightens up? would that be because of a change in the power steering pressure? (I dont really understand the actuator being a part of both the brakes and power steering system.) Thanks for the information!
Old 06-29-2015, 12:19 AM
wyoming9's Avatar
Red face
For what it is worth I have never been able to make a double flare on old brake line.
That has been exposed to the winter Chemicals it just cracks..
If brake fluid comes out under pressure you have more of a leak then you think and the level in the master cylinder is indeed dropping
Best of luck!!
mskalmus
05-28-2017 07:51 AM
andrewtexas123
07-14-2015 04:29 AM
nick b
07-11-2015 04:38 AM
87blyota
07-10-2015 04:31 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: HELP! Cannot identify part that is leaking
