Help! '86 4wd pickup, really poor gas mileage, no power in high gears
Old 12-28-2007, 12:39 PM
moorerp's Avatar
OK guys, here're the symptoms:
1. Really poor gas mileage (like half what it used to be)
2. Much worse acceleration than it should have in 4th and 5th gears (and yep, I know 22R's are underpowered to begin with, but this is way out of range even for 22R). If I stomp on the gas in 5th, the engine just hums really loudly like it's trying really hard, but no power is transferred to the drive train.
3. A lot of white smoke on start up.
4. It has a Weber 32/36 DGEV carb on it.
The only things that pop into my head are a leak in the intake manifold or a problem with the carburetor, but I pretty much don't know my *ss from a hole in the ground when it comes to stuff like this. Any ideas or suggestions from your experienced selves would be much appreciated!
thanks,
Randy
Old 12-28-2007, 09:46 PM
the_supernerd's Avatar
If there is a lot of white smoke, you could have a blown head gasket. That would also cause a loss in power. Some white smoke when it is cold is normal because of steam in the exhaust. I would doubt it is a vacuum leak because I had a big vacuum leak in my 4x2 and it idled bad but did not seen to make any difference in power. A carburetor that is way out of adjustment would cause low power and bad mileage. Also check the timing and make sure that the distributor can advance properly.
Old 12-29-2007, 08:29 AM
elripster's Avatar
Sounds like you have a blown headgasket. I would suggest a compression check to ensure the engine is healthy before tweaking or tuning anything.
Frank
Old 01-02-2008, 10:17 AM
moorerp's Avatar
thanks for the advice, guys. I'll post an update after I cross a few things off the list (like compression, etc.). Seems like this is a pretty common occurrence with old 22R's.
zd92655
03-06-2022 12:58 PM
BTOWN4RUNNER
13
06-10-2002 06:33 PM
stretch786
06-04-2002 03:22 PM
Quick Reply: Help! '86 4wd pickup, really poor gas mileage, no power in high gears
