Headbolt Dilema
FYI, and as already mentioned, 22RE head bolts are NOT TTY bolts like the 3vze from what I understand.
I reused mine about 5k ago and haven't blown up yet...
I havent got it yet, I am going to try to get it all done this weekend. Its raining now, and I havent found anything to make the homemade thread cleaner, I dont have access to much tools since I moved. An old fart at work keeps telling me to use a washer on top and let it go. I keep telling him to just stop talking, haha
Jim, where in Petersburg are you, I live in Chesterfield/Southside right off Rt 60
Also cleaning bolts is easy for me, I do powdercoating and ceramic coating and such for work, I can just sandblast them. Also like you said above, I already used copper seal and got everything all aligned, I dont wanna risk messing up a $45 Toyotas Factory head gasket
just get a tap and die. Total cost of about $10. Chase the threads and use the die to clean the bolts. The 22RE bolts are reusable - Toyota parts guy reassured me of this.
#25
Cleaning your bolts is half the solution. You should probably clean the threads in the block also. Cleaning them leaves crap in those holes (unless you can invert the motor). Best to clean them, then blow them out (a few times) with compressed air.
#26
I dont have compressed air where the truck is at, Im used to having what I need around, now Im renting and living in a subdivision so Im sure the neighbors already love my truck and the parts laying all around it.
#27
#28
then get a can of compressed air. any computer store has it.
#29
#30
I vacuumed my holes out...
They were full of oil, antifreeze and whatever else so I took a small rubber hose and taped it in the vac hose and sucked it all out.
#31
Ok, so I got my newly machine head back on my truck, Toyota head gasket and ready to go, I go to put my last head bolt in and its hard to turn. 2 bolts I had a helluva time trying to get out, come to find out it was the 2 right by the exhaust ports and they were carboned and nasty, and the bolts seemed worn down a lil above the threads, I went and bought 2 new bolts from Toyota and put them in and started the tightening sequence. The one bolt that was tight before was a little tight but went in fine and tightened down, The other was very tight and will not even tighten down all the way, Im not trying too hard cause I dont wanna screw anything up. I soaked these bolts holes with carb cleaner when I was cleaning up the block and all the other cleaned up fine. Do I need to pull the head all the way back off and go buy a tap and die set to clean these threads up? (I'd have to buy it and getting this head lined up and over the timing chain by myself was a task) Or is there anything else I can do to clean this hole up. This project is already longer then it should've been, And I havent been rushing things trying to do it right!
#32
Damn Shorty, nothin worse than being so close to done and gettin hung up! I'm 5 min off 95 at exit 50. I have some old head bolts here that I'll cut for ya if you like and get em to ya tommorow or maybe later today, have to cut the foundation for a shop my buddy and i are building this morning will send you my cell number in an email. If you havent torqued the head yet I dont think you would hurt the gasket to pull it off. But you did start that didnt you? If you only pulled a couple to the first step I'd still pull it off. Do you have a vacuum cleaner that will let you hook the hose to the blow side, if so you could use that to blow the holes out or maybe a can of co2 that you get to clean a compuyer out that would work good I think. Call me leave a message I'll be in Waverly so the phone prolly wont work.
Jim
Jim
#33
I GOT IT!! After looking for taps and stuff everywhere I gave up on that, Decided to try a new idea, I bough a small brass wire brush, It was skinney, with a long thick wire handle. I filled the hole with carb cleaner, Then went down in the hole with the brush. I did this a few times, and bough a magnet, on a bendable handle, that was just a tad smaller then the hole, Put this down in there and was pulling out big clumps of stuff, Did this 4 times, Then wire brush then magnet again. Then blew it out with compressed air (in a can) and then tried the new bolt, It hand tightened all the way down and torqued the same as the others, Now... I cant find the spacer that goes on the end of the cam between the end of the cam/sprocket and the fuel pump drive. Also missing a bolt off the plate that goes on the back of the head. I got all my exhaust studs in and the header on. So now all I got is this cam/spacer, cleaning the intake and getting it back on, Then all the accessories, dist., fuel pump, and valve cover, Vaccum lines and wires hooked back up, And driving it to the exhaust shop open header
#35
Ok, next problem, lol Is there anyway to get the hookup for the heater hose on with the intake already on. Im talking about the little metal thing that bolts to the head between the intake ports
#37
Nope, was gone all last weekend. I talked to a Toyota Master Tech today to find out about the heater line I asked about above and found out I have to take the intake all the way back off to get that on, Of course I tore the intake gasket while taking the intake back off, So I gotta buy a new intake to head gasket, Get that heater line and the box it connects to bolted to the head, then the intake back on, 2 exhaust bolts, Adjust valves, valve cover back on ( I powdercoated it at work 2 tone) Fan back on and my new radiator in, Then start it, adjust the valves again warm and drive it open header to the exhaust shop
#39
Dropped more bolts than you have turned.
Regardless of Torque to Yield or not all head bolts will stretch and weaken.
Typically weakning on the exhaust side close to a heat source. The bigger problem with reusing head bolts is typically the head is shaved and thus making the total difference from the head bolt surface to the block longer. Therfefore, you are going to lose some clamping force due to the resurfacing .005, .010, or .020 etc. Remember head bolts (not studs) are designed to stretch and apply clamping force to the threads in the block which makes it vital to ensure a clean threads in the block.
My Rules
1 - Always chase the the threads with a tap and a little grease to collect the debris, I use anti-sieze
2 - Never install any bolt with out some lubrication 30W motor is the best IMO. Most bolt manufactures such as ARP will give you Tq specs for 30W or their own lube.
3 - If you have to shave the head, either get new bolts, thicker gasket, or cut the head bolts a couple threads to compensate.
4 - Go to the parts store and get the $30 Felpros and be done!
5 - Replace the bolts in a set, Not one or two. If you are going
to reuse them put them back in their orignial holes.
6 - 22R/22RE Head Bolts 58Ft/lbs.
7 - Never user Copper Coat on a gasket that does not require it, If is says dry put it on dry!
My Rules
