head work help
Old 09-16-2008, 08:26 AM
pntbol11's Avatar
head work help
I need to put new valve seals in my 22re and also want to install a performance cam. I was wondering:
1. Is there a way to replace the vaalve seals w/o removing the head?
2. do I have to get new lifters, springs,etc. if I gat a mild low to mid performance cam?
Old 09-16-2008, 08:44 AM
DupermanDave's Avatar
I believe you can replace the seals without removing the head. When I did the head job a few weeks ago, we had to remove the head to replace a broken headgasket. While it was off, we decided to do the valves and seals too, but it wasn't necessary. It does make the job a lot easier though, if you know what you're doing (we didn't, and ended up with less bolts and nuts than we started out with)
bigjstang
08-25-2021 12:41 AM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
mickyd9990
07-06-2015 09:01 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: head work help
