Green wire in alternator bundle goes where ?
Old 04-19-2010, 01:49 PM
FleshThorn's Avatar
When I was bolting everything back after my timing chain job I found a green wire that doesn't appear to have been attached to anything for a while. It is in the same bundle as the wires that are connected to the top of the alternator with a nut. This is a small gauge green wire with a small spade connector. Where is this wire supposed to be connected ?
Old 04-19-2010, 02:11 PM
snobdds's Avatar
When I did mine, there were only three wires back there:
1. The large brown plug that goes to the back of the alt.
2. The hot connector that has the red rubber thing that slides over the top of it.
3. The ground wire that bolts to one of the powersteeirng bolts by the dist.
I never saw one that was green back there. Hope that helps...
Old 04-19-2010, 02:14 PM
FleshThorn's Avatar
I have the above three accounted for plus the green wire. Doesn't appear to be hurting anything by not being connected. This green wire is coming out of the red insulator around the hot wire.
Old 04-19-2010, 02:20 PM
iamsuperbleeder's Avatar
ground?
Old 04-19-2010, 02:39 PM
FleshThorn's Avatar
Old 04-19-2010, 02:47 PM
allnmstkn313's Avatar
Ground
Old 04-19-2010, 02:48 PM
snobdds's Avatar
I have no idea. I've never seen one like that before on my engine anywhere...
steve miller
10-10-2015 01:40 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
80Truck
07-24-2015 03:12 PM
msane99
07-17-2015 10:13 AM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Green wire in alternator bundle goes where ?
