Greasable shackles- hype? safe? worth it?
Old 10-19-2012, 11:19 PM
stanz's Avatar
I'm thinking about finally turning my attention to my sagging rear leaf springs. I am going to go new OME springs & poly bushings.
At first I was thinking I'd go with both new greaseable hanger pins and greasable shackles. After doing some research, I found a number of posts on greasable hanger pin failures.
It seems that everyone sells greaseable shackles. I'm curious what the failure rate of the hardware is on these? Are they worth the extra $$?
Thanks in advance.
Old 10-20-2012, 01:19 AM
wyoming9's Avatar
Red face
Be nice to know just how these hanger pins failed.
What kind of use.
If I needed to redo my rear springs and I had the luxury of being able to get these parts in a timely manor I would most likely go with them.
Old 10-20-2012, 05:55 AM
brianh699's Avatar
My bro has Downey (no longer in business) extended shackles with greasable pins and urethane bushings, on his 93 2wd. This little pickup is rode hard and put away wet. Never had any problems with them, and ride quality is much better with them.
Old 10-20-2012, 06:16 AM
Fossilized
Staff
dropzone's Avatar
Links to these posts with failures??
I use them..
Old 10-20-2012, 07:51 AM
stanz's Avatar
Here's one link that I was referring to: http://forum.ih8mud.com/40-55-series...ring-pins.html
Note: the hanger pins are the bolts for the forward spring mounts in the rear, not the shackle ends.
Old 10-20-2012, 08:27 AM
wyoming9's Avatar
Smile
well yes I had 3 tons of lead bars in my pick up and backed over a Two foot drop yes I can say my homemade Chinese Hardware failed.
Along with other things but that is not important
Old 10-20-2012, 08:51 AM
westjohns yota's Avatar
it looks like it weak due to the point were the zerk is fitted into, def wouldnt buy
vikinghug
06-14-2016 08:10 PM
Scottcrb
03-03-2016 11:57 AM
IntoTheVoid
10-24-2015 04:54 PM
Truckwithoutaname
10-03-2015 03:41 PM
kcaudill
09-11-2015 02:49 PM
Quick Reply: Greasable shackles- hype? safe? worth it?
