Gear confusion on my 93 4runner.
Old 03-07-2011, 04:31 PM
nsb22's Avatar
My sticker on my door says I have 4.30 gear ratio, but my truck is a manual tranny, r150f.
Looking at the 4crawler webpage, it stated the 4.30 would/should be in a truck with auto tranny.
I'm confused and looking for some help.
Old 03-07-2011, 04:38 PM
eric-the-red's Avatar
The door stickers on both my 4Runners, a 93 and an 01, are incorrect so i wouldn't go by that. The easy way to check is jack up one rear wheel, spin it 2 complete turns and count the driveshaft turns. That'll give you the ratio.
Old 03-07-2011, 04:48 PM
nsb22's Avatar
Will do. Thanks.
Sponsor
Tofer's Avatar
My brothers truck had 4.30s and a 5sp
Old 03-08-2011, 05:48 AM
Wrenchinjoe's Avatar
The door sticker in my 93' lists a gear code of G284. If I read that correctly (and assuming the sticker is correct) I should also have 4.30's with the R150F.
Old 03-08-2011, 05:50 AM
waskillywabbit's Avatar
Look at ErikB differential page.
Spin and count. It's not hard.
:wabbit2:
Old 03-08-2011, 05:51 AM
nsb22's Avatar
I'll be spinning and counting tomorrow. I just wondered if there is a reason it would have come with that set up. That's all.
Old 03-08-2011, 05:57 AM
I never trust the code. I always spin and count and if rebuilding the axle, just count the R&P and mark the diff. With all the older Toyotas I see, no telling who has done what in 20+ years to the vehicle. I saw a set of 5.71s the other day. They looked weird.
:wabbit2:
Old 03-08-2011, 06:01 AM
Team420's Avatar
G284... I'd double check... but I'm pretty sure thats the cose for 4.88's, and that would make sense for an auto....
whoops.... my bad... I just looked, G144 = 4.88's, G254 = 4.56's.... cant remember 4.10 or 4.30...
U prolly have the 4.10.... being as its a 5spd
Old 03-08-2011, 12:51 PM
toyota4x4907's Avatar
G294 is 4.10s, G284 is 4.30
Old 01-24-2012, 03:50 PM
mpwarfy's Avatar
I have a question.... so different codes can be the same ratio? G284 is 4.30... my 4runner is 4.30 but my code is G282. the reason i ask is i have been searching high and low for a rear end for my 88 4runner and looking specifically for that code.
Old 03-06-2012, 04:52 PM
toyrunnerns's Avatar
yours is a 22re with 2 pinion diff
Old 03-06-2012, 05:04 PM
MudHippy's Avatar
1993 4x4 4Runners with a V6 came with 4.30, 4.56, or 4.88 gears.
1993 4x4 4Runners with a 4 cyl. came with 4.10 or 4.56 gears.
Transmission type has nothing to do with it. Especially since with ALL 1993 4x4 4Runners, 4 cyl. and V6, a 5-speed manual transmission was considered standard equipment. The 4-speed automatic was only available as an option.
Ironmike4x4
02-03-2016 11:13 AM
deepmarsh
08-06-2015 03:44 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Athansinis
07-27-2015 08:38 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: Gear confusion on my 93 4runner.
