| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
gas in oil
#2 (permalink) |
that's bad news. it's leaking from the cylinders past the rings. that will kill an engine pretty quick. so your sure it's gas in the oil and not water? does the oil smell like gas. take a little sample and try to light it with a match to see, of course far away from your vehicle.
__________________
-89 deluxe 4runner 22re/A340H -85 extended cab 4x4 with 22r/G52 -89 corolla 4af |
#3 (permalink) |
yes,it smells like gas, but by the rings? this truck has never used oil and always runs good.
#4 (permalink) |
Sounds like your engine is running very rich, and the fuel that doesn't get burnt is running down the cylinder walls into the crankcase. That is not good because as the gas runs down the walls it washes away the oil so your rings aren't getting lubricated and will wear quicker.
#5 (permalink) |
the condition needs to be adressed before it is a problem and you do end up using oil. figure out why you are flooding the cylinders. i wouldn't continue running the truck untill it's fixed.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil & Gas | celica | Off Topic Talk | 7 | 04-13-2006 02:57 PM |
| Diesel oil in a gas engine?? | NoLookingBack | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 09-16-2005 08:10 PM |
| Why does my oil smell like gas?? | epic37311 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 01-06-2005 03:06 AM |
| gas vs. oil charged shocks ??? | humanoid | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-18-2003 07:04 PM |
