Fuel filter replacement
Old 11-21-2013, 09:26 AM
bspeth's Avatar
Do you guys know the torque specs for the banjo nuts on the fuel filter for a 22RE? Also is a flare wrench required for this procedure or will a regular wrench work?Thanks
Old 11-21-2013, 09:42 AM
scope103's Avatar
What Sayeth the Good Book? http://personal.utulsa.edu/~nathan-b...46services.pdf (22 ft-lbs)
Doesn't the 22re use 2 banjo bolts on the fuel filter? (the 3VZE does not) If so, you'll want to use a socket wrench or box-end wrench. The bolts aren't real hard, so using an open-end wrench risks chewing them up. You don't need flare-nut wrenches on banjo bolts.
Old 11-21-2013, 10:41 AM
bspeth's Avatar
Yes banjos.Thanks for the info.
Charecter1
11-06-2023 10:08 AM
jbv808
08-06-2021 04:47 PM
TURBOrunnerNM
07-22-2015 11:01 AM
smiley52
07-11-2015 05:16 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Fuel filter replacement
