fuel filter
Old 09-05-2014, 12:47 PM
goose hunter's Avatar
fuel filter
Where is the fuel filter located on a 1988 4runner
Old 09-05-2014, 01:48 PM
Badger62811's Avatar
ummmm 22re or 3.0?
Old 09-05-2014, 01:49 PM
22re.
Old 09-05-2014, 02:02 PM
Should be on the passenger side under the intake, bolted to the side of the block. Very hard to see/get to with everything assembled. I had the luxury of replacing mine while I had the head torn off while doing my head gasket. Hope this helps.
Old 09-05-2014, 02:05 PM
Is this it?
Click image for larger version
Old 09-05-2014, 02:08 PM
No. That would be your charcoal canister.
Old 09-05-2014, 03:04 PM
wyoming9's Avatar
Red face
It is above the starter below the intake .
Some just remove the fuel lines and relocate the filter to the inner fender.
Old 09-05-2014, 03:06 PM
That too.
Old 09-05-2014, 03:42 PM
jennygirl's Avatar
Easiest way to get to it is through the passenger side service access panel.
Jack the car up in front and throw a jack stand under the passenger side, take the passenger side wheel off.
Then remove the access panel in the wheel well. It's pretty much a straight shot to the fuel filter, which is mounted laterally with two 17mm bolts on either end holding it on. Also might want to disconnect the battery negative before wrenching it, the starter positive is right there.
Old 09-05-2014, 05:39 PM
I like to live dangerously.
Old 09-05-2014, 11:15 PM
wyoming9's Avatar
Red face
Not real sure what engine Jenny has but mine has 8MM bolts holding it to the block
Then you have the 2 Banjo bolts holding the fuel lines on perhaps that is what she meant.That take a 17mm wrench
Old 09-06-2014, 12:59 AM
jennygirl's Avatar
Must have gotten them mixed up! Oopsie That sounds right
Old 09-06-2014, 01:17 AM
Staff
Terrys87's Avatar
I have changed numerous fuel filters on the 22re and never disconnected the battery and then one time I did disconnect the fuel line and I heard a crackling noise. It was fuel running down to the starter and luckily it did not flame up. From now on I always disconnect the battery. Just something I never thought about until it happened.
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
pyramid
07-30-2015 10:05 AM
ddg71
07-24-2015 01:24 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: fuel filter
