Front Passenger Side Grind
Old 11-11-2009, 10:01 PM
limon32's Avatar
Winter is upon my and a problem that I've been hiding from has returned:
Last spring, when I had my hubs turned in and had the t-case in 2wd, I could hear a grinding/rubbing sound from the front passenger side.
I've spent most of the summer running around the beach with the hubs turned in and 4x4 working fine.
Today, I turn in the hubs and drive around the block in 2x4 and grinding occurs. Shift into 4x4 and grinding stops while accelerating and maintaining speed, starts grinding as soon as I let off the gas
I have replaced the inner and outer wheel bearings on that side, they were bad but didn't change this problem. I'm curious if there is another bearing on the inboard side of the inboard CV joint?
Any ideas would be greatly appreciated!
Old 11-11-2009, 10:09 PM
peow130's Avatar
Dry spindle, mine did it all last winter too.
https://www.yotatech.com/forums/f116...ctures-100327/
There is a small bushing on the inside of the spindle.
Old 11-12-2009, 09:38 PM
limon32's Avatar
Awesome, really appreciate it!
Old 11-12-2009, 10:04 PM
peow130's Avatar
no problemo
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
razorman8669
07-12-2015 12:13 PM
crashburnoveride
07-10-2015 06:39 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Front Passenger Side Grind
