front diffs blown up & its a 4:30 G/r ?
Old 01-27-2011, 04:59 PM
jjyoda_86's Avatar
so I have a 93 yota v6 3.0 I was wheeling this last weekend and heard something pop in the front end pulled the front diff cover and I destroyed my ring gear. i checked my ratio and it comes out to 4:30 and I cant find anywhere that carries that ratio. also i wanted to put a limited slip or possi in there. Any recommends thats stong and cost effective.
Old 01-27-2011, 05:23 PM
ohoktimmyg's Avatar
do research on the gear tag found on the inside of your truck's door jamb. there are numbers on there that will identify what gears were in it. this website has answers for anything you're looking for.. you just have to look.
Old 01-27-2011, 05:32 PM
RMA
RMA's Avatar
curious as to how you checked your ratio ? i Have one with the blue paint at the nut , but when i opened it up it counts out to 41-10...
heres 4crawlers page
http://www.4crawler.com/4x4/4R_TechI...#Differentials
cr@ves4wheelin's Avatar
There's gotta be 4:30 gears selling somewhere, have you googled it yet? I didn't know that came stock for pickups, but I guess the pinion paint code would be blue for that according to this. http://www.pirate4x4.com/forum/showthread.php?t=190640
Old 01-27-2011, 05:33 PM
ohoktimmyg's Avatar
https://www.yotatech.com/forums/f116...-first-214051/
Old 01-27-2011, 05:35 PM
INFINITY's Avatar
X2
Old 01-27-2011, 06:59 PM
MB4runner's Avatar
Don't see where he was asking how to find his ratio. Looks like he was asking where to BUY 7.5" 4.30s
As far as that goes, good luck, have never seen them for sale. Best bet is maybe a wrecker, print out the list of codes, take it to the wrecker, check the door jamb for the gear code against your list and maybe you'll luck out.
Old 01-27-2011, 11:03 PM
85toyman's Avatar
92 thru 95 4runners 3.0 with a 5spd and 225 tires usually have 4:30 gears in them. I had a couple of sets from from 4runners I had parted out. I have since sold them, but that is what to look for if you want 4:30 gears. You can't get them new from anybody that I have found that sells gears.
Old 01-27-2011, 11:12 PM
MudHippy's Avatar
Also 86-88 PU/4Runner with automatic transmissions have them, which all had 225/75s(so that's not worth investigating). Look for axle codes G282 & G284.
http://www.off-road.com/trucks-4x4/t...ion-18588.html
Old 01-28-2011, 08:16 AM
85toyman's Avatar
thanks for the additional info mud hippy. Always like to learn something new
Old 01-28-2011, 07:01 PM
ZUK
ZUK's Avatar
Hi jjyoda-- I have a nice, used 430 7.5" for $75 delivered to you price if you want it....but I don't do the installation anymore. I'm having too much fun camping ZUK
10 teeth on the pinion and 43 on the ring.
Old 01-28-2011, 09:16 PM
jjyoda_86's Avatar
well i pulled the front diff out yesterday and counted my ring and pinion gears I have 43 ring and 10 pinion which is the rare 4:30. I think im going to upgrade my gear ratio to 4:56 with superior front gears. im going to check out the local junkyard for a rear used 4:56 third member. If anyone has a limited setup for the front or rear for sale im interested. i also checked the vin stamp and its deffinetly the 4:30
Old 01-28-2011, 09:22 PM
MudHippy's Avatar
Are you sure? Because I'll snag those 4.30s if you don't want 'em.
How 'bout it? Still for sale? How do I get those from ya?
Old 01-29-2011, 02:17 PM
Ezrider_92356's Avatar
id be interested in them as well for the 7.5 rear on my 2wd
Old 01-29-2011, 03:47 PM
ZUK
ZUK's Avatar
I checked my stock and I have one more good 7.5" 430 set......all the rest are 8" 430 sets.
Old 01-29-2011, 04:27 PM
4.30's would be a huge improvement over the 3.27 that i have now with 31's want 33's eventually 4.30's would probably be a good gear choice. let me see where I'm at Monday after i get all my bills paid
Old 02-03-2011, 05:47 PM
jjyoda_86's Avatar
I think Im going to keep my 3rd member just b/c I think I could use it another day, my garage is filling up w/ parts from toyotas and im collecting more just cause i like yotas.
I picked up a used 3rd member from our local bone yard for $150 w/ 4:56 out of a tacoma I believe cause it has the abs unit at the top of the diff. I installed it today and its all ok I like the power difference so far, Im ordering my front gears when I get my taxes. And then wheeling here I come to test them out.
Daneums
08-20-2015 05:36 AM
jaretstuff
08-04-2015 02:08 PM
Steven.m.paulk
07-24-2015 01:44 PM
scottyg486
07-19-2015 05:34 PM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: front diffs blown up & its a 4:30 G/r ?
