ford 9inch rear end leaking gear oil still
Old 08-31-2009, 10:19 PM
TrevanO's Avatar
Exclamation ford 9inch rear end leaking gear oil still
i have an 76 ford 9 inch rear end, both seals are leaking gear oil bad. i replaced one side (big hassel you have to cut off the retainer and bearing to then press on the new parts. I made sure i had the right seal but it almost didnt want to seat in the axle right. I ended up getting it in the best i could but it still leaks! anyone have any expeirence with Ford rear ends?
Old 08-31-2009, 11:11 PM
88toyblackjack's Avatar
There are several variations in seal sizes. The ones I got from the local auto parts leaked right away because I warped it to get it to fit. I got some good ones from Motion Industries(industrial bearing and seal house) and took my time installing. Also be sure not to rest the axle on the seal lip when installing. remember, spring side of seal to the inside
Old 09-01-2009, 04:21 AM
baseballchamp157's Avatar
i helped a friend install some seals in his 78 f150 and it was a pain. after a couple hours we got them in and they still leaked. so dont feel bad, your not the only one
Old 09-01-2009, 01:58 PM
TrevanO's Avatar
yea they're leakin bad. I dont know what i should do. I might try silicone
voiddweller
19
05-02-2016 09:10 PM
bigblue82
10
07-06-2015 08:27 AM
merc1100sc
06-26-2015 05:24 PM
newzingo
06-19-2015 04:37 PM
Quick Reply: ford 9inch rear end leaking gear oil still
