Flowmaster origianal 40 or Delta Flow 40? Opinions? thanks
Old 10-20-2009, 10:05 PM
Linksys67's Avatar
SO i can't really decide between getting a Flowmaster 40 Original series or Delta flow for my 1995 toyota pickup 4wd 22re. I'm planning to put it on 2.25" piping with a pipe inplace of my cat for easy replacement when needed. Does anyone know the difference between these mufflers? and opinions? thanks !
Old 10-20-2009, 10:09 PM
91Toyota's Avatar
The delta flow is quieter. You can go on to there website and look at the muffler designs. I have the 40 series delta flow on my truck.
Old 10-20-2009, 10:10 PM
70elcoss's Avatar
im pretty sure the delta flow is quiter than the 40. i have a 70 el camino ss with the 40's and you can hear it blocks away, but my friend has a late 60's truck with the same engine as mine and deltas and its considerably quiter. its personal preference really, do you want loud or quiet
Old 10-20-2009, 10:11 PM
Elton's Avatar
i had a header no cat 2.25'' pipe to a delta 40 on my 22re it was pretty loud heres a clip no the best but u get the idea http://s63.photobucket.com/albums/h1...t=f218f311.pbr
Old 10-20-2009, 10:12 PM
Linksys67's Avatar
how do you like your delta flow? is it too quiet or just right? do you have pipping out the back behind the wheel?
Old 10-20-2009, 10:14 PM
Linksys67's Avatar
oh wow i like the sound of your delta flow Elton, sounds just like i want it. Thanks i think you made my decision with that clip!
Old 10-20-2009, 10:28 PM
Elton's Avatar
yea the header made it that much louder but i loved it
Old 10-20-2009, 10:39 PM
91Toyota's Avatar
I have a 2" delta flow. Its the smallest one they make...because I just wanted to be able to slip it over my stock exhaust w/o cat and run it like that. It sounds good at 3k rpm. I like it!
Old 10-20-2009, 10:48 PM
Linksys67's Avatar
well i would like it to be loud on the outside just not on the inside of my truck. i will have it piped all the way out to where the stock piping goes. still iffy but leaning towards the delta flow even tho my friend says original.
Old 10-20-2009, 11:05 PM
91Toyota's Avatar
I have mine cut off right at the end of the cab...so I get alot of cab noise.
Old 10-21-2009, 06:10 AM
Dipstik_90's Avatar
I had a delta flow 40 on my truck. Took it off after a while cause it was too loud, replaced it with a 50 series much nicer to drive now way less drone.
Old 10-21-2009, 06:27 AM
yodta's Avatar
I also have the 50 series on my truck, the Deltaflow model. I experimented with several mufflers, including Magnaflow. I like the Flowmaster better. it's got a nice mellow sound, and it's not buzzy.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
Iceman4193
10-16-2015 10:50 AM
drifttruck
09-18-2015 11:19 AM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: Flowmaster origianal 40 or Delta Flow 40? Opinions? thanks
