Finiky IDLE! advice?
Old Nov 6, 2007 | 07:51 PM
MIKEMOKAS's Avatar
hey guys...
i was wondering if you could help me find out what i need to do to fix my idle problem...?
its been acting up ever since i "ATTEMPTED" to fix my leaky valve covers...
fist i though it was some mixed up vacuum lines, got a diagram, checked mine, swapped around a few lines that i mixed up and thought it should be back to normal....
it wasent.
now its doing this almost all of the time now, its really pissing me off.
heres whats happening..
when i first start the truck up in the morning it revs up to 1500rpm and then goes down to 500 and it keeps going back and forth untill you take off and drive.. once the motor warms up it usually idles fine, but every once and a while it will do this...
^^^this has been happening more recently lately.. thats why im forced to post this..
(note that the only time it holds stady in the video is because or me)
it surges between say 200-300rpm and after a couple times of going back and forth it will stall out.
heres what im thinking..
1) new fuel filter?
2) i need to raise my idle (but why would i need to do that? its not like i changed any settings when i did the valve covers...)
3) fuel pump maby going bad??? < please say no...
theres no vacuum leaks.
thanks for any info/ suggestions!...
Old Nov 6, 2007 | 08:16 PM
Elvota's Avatar
Have you adjusted or messed with your TPS at all?
Make sure there isn't a tear in your intake... the extra air could be messing with the computer. Maybe you tore it (they get weak) when doing your maintenance?
Just throwing out some ideas.
Old Nov 7, 2007 | 04:41 PM
MIKEMOKAS's Avatar
i dont even want to tell you guys why it was surging, i feel sooo dumb...
wow
it still idles really high and surges when cold but gets better once it warms up, ill video it tomorrow morning.
ttyl
Old Nov 7, 2007 | 05:18 PM
Justinvd's Avatar
Its doing that on its own?
Old Nov 7, 2007 | 06:20 PM
MIKEMOKAS's Avatar
i was revving it, trying to get it to idle correctly... o, and i held it steady...
but the surging, that all the truck...
Blamalam
Mar 12, 2022 07:34 AM
Eggslinger
Jun 8, 2019 03:32 PM
accuracy
Aug 4, 2015 08:05 PM
Sidherish
Aug 2, 2015 01:42 PM
kyletbert
Jul 17, 2015 11:39 AM
