Finally dug into my rear axle project today...
#41
Yes, they are side specific. If you read through the thread, you will see I swapped them out & they back all the way off.....so I put them back the way I had them.
I've about determined I just need to replace the adjusters, but don't want to spend the $$$ if something else is causing the problem.
#43
Is the adjuster lock touching the adjuster gear? And the side you have pictured is the right side correct? The R stamped on the adjuster lock states which side it goes on. The right side would be the passenger side.
In your pictures the adjuster is deff way to far out......so It is a definitely a problem with the adjustment.
Are you sure the shoes are your your truck? I would take the shoes off and place them in side of the drum and make sure they are sitting properly inside the drum.
just my .02
just my .02
#47
sorry to bring up the old thread, but I did the passenger side a year ago, now Its time to do the front, and why not do the other side too. I cant remember for some reason, but I know there is the outer seal, but that inner big tube like seal, where does that guy go? I got the seal, bearing, retainer and c clip, but where does this guy go
#48
Axle troubles?
I summarize some of my axle repairs on my web site(link below). I even made my own bearing press for those half shafts using scrap lumber with a hole drilled threw it for the axle and a bottle jack. Very dangerous, went through several design iterations before making a smaller one whose 12 inch think wood members would not snap in half do to the larger internal bending moments associated with a longer span (especially in the middle). Any way it sucked alot because the fact a bearing had spin escaped me for the longest time. The eccentricity of the axle due to the spent bearing allowed the lips around break drum to ride on the back plate as a plain surface bearing ( designing this fail safe was very good idea, Toyota). Another consequence of axle eccentricity allowed the brake cylinder to leak by mucking with fine brake cylinder travel requirements. A combination of the friction and oil caused it to smoke. I changed the cylinder three times! and still was driving with this smoke lol. Then i changed ALL break hardware including springs, adjusters drums, callipers, pins and so on. AND it was STILL leaking! I finally noticed the axle was a bit eccentric(off Center) i looked at a diagram on the axle in the factory manual and determined it was the bearing, and sure enough when i finally took the axle out there was a crap bearing with loose balls that shifted to on one side leaving less on the other. I changed the bearings collars, and seals on both sides using my make shift bearing press (something i could imagine at a mechanics garage in a third world country).
http://www.craigginsberg.com/safari-battle-cruizer/
#49
Drum removal
Get a drum brake hard ware kit. look on ebay. You can replace ALL the hardware for like 20 bucks.
Also i suggest you put the springs on the shoes FIRST then use the shoes for leverage as you pry open the spring as you place it on the vehicle. I found this to be the easiest way.
#50
Sorry man I don't have any advice on why your brakes are sticking, but just for the future, Toyota drums have two 10x125 threaded holes 180 out from each other that you can thread bolts down in to remove the drums.
Good luck
Good luck
#51
I've determined the e-brake cable wasn't adjusted enough to allow the bottom of the shoes to touch, so the adjuster was trying to take up ALL the braking slack.
Anyone have any advice for tightening the e-brake adjustment? It just spins...no way to hold it still to get the nut tighter (doesn't look like it's moved since 1994!)?
#52
ebrake ajustment
#54
#55
Huh...it's all in my sig line, but none of the sig lines are showing up today....weird.
Stock '94 DLX XtraCab 4x4 5 spd, Fully Rebuilt 3VZE, 17" 2006 Alloy Wheels, 257k miles, AISIN Manual Hub Swap
Flying91
45
04-11-2024 04:39 PM
jerusry
10-19-2015 05:28 PM
