Fender Trim
Old Nov 26, 2007 | 03:45 PM
DanStew's Avatar
Fender Trim
Isit glued or botled on? I think it is glued but i havent pulled on it and dont want to tear it yet while removing it.
Old Nov 26, 2007 | 05:27 PM
4runnerx3's Avatar
Chrome trim? it's screwed on.
Old Nov 26, 2007 | 05:33 PM
DanStew's Avatar
yup, chrome trim over the fenders openings/
Old Nov 26, 2007 | 05:44 PM
seanz0rz's Avatar
Guest
yep its got 10mm/phillips bolts and some connector things that stick in the fender (cant remember if the chrome is between the bolts and connectors or the connectors and fender)
Old Nov 26, 2007 | 05:46 PM
DanStew's Avatar
OH so if i remove it there will be little hoels left around? Darn i thoguht it would leave it clean. I guess i will leave it i do not feel like filling holes at this moment in time
Old Nov 26, 2007 | 05:49 PM
Etype R's Avatar
Its bolted through inner lips of the fenders, that also hold the plastic tubs in place. You put the bolts back in place after removing the trim.
Old Nov 26, 2007 | 08:32 PM
Jay351's Avatar
Mine was kinda stuck from all the grime and much. Took some paint off with it.. But the chrome stuff only causes rust.
Old Nov 27, 2007 | 08:40 AM
AUYota's Avatar
no it's not drilled into the body but screwed inside the fender area. I took mine off and threw them in the garbage- they create a water trap in the rear and have rusted that whole rear fender rim.
Those things looked stoopid too me...
Old Nov 27, 2007 | 10:03 AM
DanStew's Avatar
Cool. i felt around the wheelwell today and know how it is on. they will be leaving soon. I will try to soften up adn crud under them as to not pull away any paint. sine there is no rust under them i want to keep it that way
Old Nov 27, 2007 | 12:53 PM
InternetRoadkill's Avatar
Get rid of them. They trap dirt and water and are a prime rust maker.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
toyotasaurus
Sep 24, 2015 03:30 PM
BimmerSage
Sep 17, 2015 11:48 PM
justdifferentials
Sep 5, 2015 06:52 PM
