Fan noisy at highway speeds - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2009, 10:02 AM   #1 (permalink)
'92 Pickup, 3VZ-E, 5spd.
I've noticed that the fan gets noisy after driving at highway speeds for a while. The same sound it makes when you start it up cold, or when the A/C is on.
This is not when the A/C is on, since it's November, just after a while of driving at like 65-70, I can hear that the fan clutch has tightened up and I get the loud fan whirring noise.
Doesn't do it around town at all, even if I am driving around town for a couple of hours, which is stop and go, so I would assume running hotter.
Still semi new to this truck, so not sure if this is a normal thing for the fan to do at hwy speeds or what.
Thanks.
mmcpeck is offline
Old 11-08-2009, 10:20 AM   #2 (permalink)
yotaman90's Avatar
Yes its normal. When you pull off of the highway, the engine is no longer being cooled by 70mph wind. Thus, the fan clutch engages and you hear the familiar whirring sound of the fan
__________________
Eric
1994 4Runner|3VZ-E|A340H|103,XXX miles|31x10.50 BFG All Terrain T/A KOs|my DD
1987 4WD Pickup|Xtra-Cab|22R|G52|245,XXX miles|Rancho RS 5000 shocks|MC shifter bushings|235/75R-15 Dunlop Mud Rovers|ATM clutch|custom headache rack|SR5 gauge swap|LCE carb adapter+K&N filter
Quote:
Originally Posted by DeathCougar View Post
I am holding up one finger. And one finger only. I shall not describe which finger it is, as that violates the rules. But suffice to say its a very definitive finger.
yotaman90 is offline
Old 11-08-2009, 10:20 AM   #3 (permalink)
yoterr's Avatar
shouldnt be, maybe your fan clutch is getting stuck? i dont have a 3vze but my old ford's was stuck on all the time, sucked gas n HP (6cyl 5spd) i got an electric fan off of summit for 200 best mod i ever did for that truck
__________________
new to me 86' toy on 35" procomp mud terrains, with a 4" lift and 3" body and palm fron camo for now...
04' Dodge 2500 4x4 QC hemi leveled, home made CAI and flowmaster exhaust
yoterr is offline
Old 11-08-2009, 10:29 AM   #4 (permalink)
Quote:
It's not when I pull of the highyway, it's on the highway going 70, you can hear the fan whirring.
I don't think the clutch is stuck or else I would hear it all the time. Plus I can hear the clutch in lock up when it is started cold and then lossen up after 30-45 seconds or so, as it should. Also it will lock up when you run the A/C, as it should. But driving around town it doesn't do it, noticably at least.
If you sit at a light for a while or sit idling for whatever reason it will lock up, because it's sitting, and you can hear it when you start to go, but then comes off again in a few seconds, all normal.
I just though it was weird that it was locking up and coming on at 70mph with all that air moving across the engine.
What makes it lock up and disengage anyway, I heard once that there is some kind of gel or something in the clutch that is temp activated and gets thicker and thinner with/without heat?
mmcpeck is offline
Old 11-08-2009, 10:31 AM   #5 (permalink)
yotaman90's Avatar
Does your temperature gauge read hotter when you're at highway speeds?
__________________
Eric
Old 11-08-2009, 03:14 PM   #6 (permalink)
No, temp gauge reads perfectly normal the whole time, nothing else abnormal, just hear the fan whine.
mmcpeck is offline
Old 11-12-2009, 05:30 PM   #7 (permalink)
So I guess this is normal then?
mmcpeck is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
