Extended brake line length
Old 07-03-2006, 08:05 PM
MorphiasX's Avatar
Im going to be going with the Total Chaos Gen 2 Caddy kit in the front which lifts the truck 4", then going with new leaf packs in the rear (Downeys, Deavers, or Trail-Gear) to lift the rear 4" as well. My question is, how much longer do my brake lines need to be? 4" longer than stock? The reason I ask is, I currently have an 02 Tacoma TRD rear end in my garage that im going to be swapping under my truck in a few weeks. I need to do it SOON because my third member gasket (where the third member seats into the axle housing) is leaking, and I dont want to do anything about it since I am going to be putting the new rear end under there. Anyways, the TRD rear end is wider than my current rear end (1.5" wider I believe so .75" on either side) and so I need to get extended brake lines, well if im getting new brake lines, I figure I might as well get the ones I will need for the lift now, and just tie the slack out of the way. I will be getting good SS braided lines from a local shop.
Old 07-03-2006, 08:22 PM
Elton's Avatar
i would think 4'' over stock should be ok
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
CanRunner
07-20-2015 01:29 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Extended brake line length
