ENGNBLDR FEK 4 piece front end kit contents
Old 01-07-2011, 02:08 PM
AimCOTaco's Avatar
Per Ted at Engnbldr.com, the ENGNBLDR FEK or 4 piece front end kit contains:
"All of the front end gaskets and seals are included in our timing kits, and there will be some spares as the oil pump have the oil pump seals also.
Yes, a new tensioner is also in the kit, we use the OEM piece only.
Thanks,
Ted(engnbldr)"
EDIT: KIT CONTENTS LIST:
*note, your results could vary, here's what I received in January of 2011...
ENGNBLDR FEK 4-piece
Oil Pump: Oil Pump with crank main-seal pre-installed, pump o-ring.
Water Pump: Water Pump, Gasket, Drive Flange Studs.
Timing Cover: Timing cover only
Timing Kit: Crank Sprocket, Cam Sprocket, Chain, Timing Cover Gaskets, Crank Main Seal, Oil Pump o-ring, Steel Backed Guide, Plastic Guide, Guide Mounting Hardware, OSK MADE IN JAPAN TENSIONER!
-yep, you end up with a spare main seal and oil pump o-ring.
*I had searched awhile and could not find the contents of the kit or if a tensioner was included and/or which tensioner was included..
Timing set kit chain contents tensioner
Hopefully this helps someone someday, Happy Friday,
Old 01-07-2011, 02:53 PM
Stuwy123's Avatar
It's probably a Rock Auto tensioner.
Talk to Ted, he's awesome. Great customer service.
He'll tell you whatever you wanna know.
Old 01-07-2011, 03:46 PM
AimCOTaco's Avatar
OEM tensioner
Maybe a Rock, but Ted's e-mail said OEM so I was guessing OEM Toyota rather than Rock... We'll know next week when the kit arrives and I will clear it up.
Old 01-07-2011, 04:18 PM
waynesworld's Avatar
i really don't think it's a toyota factory part cause just the tensioner costs 54.09 @ toyotapartszone.com ,its got 2b a rock, like stuwy123 said.
Old 01-07-2011, 04:29 PM
xxxtreme22r's Avatar
the timing kit from EB is a rock product. At least it was when I did my rebuild.
Old 01-16-2011, 04:41 AM
engnbldr's Avatar
>>>*Actually, we package the kits with a tensioner which is the same as the factory item. It's done though an inter company buy agreement.
A tiny little company like ours can't always purchase enough at once to get the best prices so we sometimes gang up on the orders. We did that way back.
Yes, the kit comes with the tensioner, and yes, it is from the original equipment factory....*EB
Old 01-16-2011, 06:14 AM
well that settles that , then i geuss i will b ordering mine this week ! kool ! thanks eb!!
Old 01-16-2011, 07:32 AM
AimCOTaco's Avatar
Nice Kit!
Nice Kit! Installing today with a little luck.
I'm super happy with what I received for what I paid! I was unsure of EB just because of the great prices, but after checking up here I decided to go for it and could not be happier! The castings on the pumps and cover are very nice and don't look at all second rate, nice uniform finish and no casting voids at all that I can see, nicely tapped holes, nicely ground mounting faces, etc.
Most importantly the Japanese OSK tensioner in the kit I received looks awesome.
Can't go wrong with this kit in my opinion, I usually only buy OEM and I would buy this kit again in a heartbeat. Save some cash without really cutting any corners!
Order 'em up!
icentropy
09-16-2020 02:47 PM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
karbin
07-05-2015 11:37 PM
Quick Reply: ENGNBLDR FEK 4 piece front end kit contents
