engine and transmission swap
Old 07-04-2012, 10:44 PM
edwinstoyota's Avatar
I got a 91 toyota sr5 4x4 with the 3.0 v6 and auto transmission i was wandering how hard it would be to swap this combo out and put a 22re and 5speed in? Any info is appreciated and helps thanks!
Old 07-04-2012, 11:44 PM
wyoming9's Avatar
Wink
Quite a few threads on this!!
It would all depend on your idea of hard.
Hanging the clutch pedal running the hard line.New Clutch Master and Slave cylinders.
Rear drive shaft might need to be changed if the length is different.
Merging the engine harness to vehicle harness. remembering to jumper the neutral safety switch or it will never crank.
cutting the hole in the transmission tunnel bigger to take both shifters.
A new Clutch kit and flywheel with new flywheel bolts
If you are going to all this trouble why not a 3.4 no doubt you have the 22re.
It really helps to have the parts vehicle there to save countless trips to auto parts stores and the used parts sources of your choice.
For the little parts that get lost or are never thought about like the pin that connects the master cylinder to the clutch pedal. The bracket where the hard and rubber line join above the slave cylinder etc.
Old 07-05-2012, 01:45 AM
Staff
Terrys87's Avatar
It would be a big job. Motor mounts arent the same either.
Old 07-05-2012, 04:36 AM
Mr.Utah's Avatar
Probably easier and cheaper to buy another truck with the set up you want. There are many hidden costs in all this potential work. I know many wheelers who prefer the auto tranny?
Old 07-05-2012, 09:06 AM
thanks for all the help im not sure what my plans are the money would be the deciding factor and it seems very pricey either way i may scrap the ideaand try to find a different truck again thanks for all the help i new to the forum!
Old 07-09-2012, 07:57 AM
FZRDude's Avatar
Since we are one the topic of Trans, 3.0's, 22R's, and the swapping thereof....
I have one 90 Runner 3.0 Auto and one 91 Runner 22R 5-speed (totaled truck). My question is: What manual trans bolts up to the 3.0? Is it possible to swap in the 5-speed from the 22R, or should I look for a manual trans (and ECU) from a 3.0/3.4 donor truck?
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
God's Bounty Hunter
07-08-2015 12:54 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: engine and transmission swap
