engine swap!!??
Old 05-20-2008, 09:05 AM
yota4life6's Avatar
engine swap!!??
Newbie here.....
Looking to replace my cracked 3.0 3vz in my 95 4runner 4x4. I came across a good deal on a 95 Camry 3.0 v6 and was very curious if this motor is compatible? Im assuming no, but had to ask!
Thanks in advance
Old 05-20-2008, 09:09 AM
rdlsz24's Avatar
Well anything is possible with time and money but I think you would be better off finding another 3VZE or better yet a 3.4.
Rob
Old 05-20-2008, 09:11 AM
crolison's Avatar
I dont think it would work as a direct bolt up, but like they will say with the money anything can work. I believe thats the 1mz engine, which is designed off of the vz block but in aluminum.
If I was in your situation I would do the 3.4 swap, its a direct bolt on with a little bit of wiring, which you can get from offroad solutions as a plug and play kit i believe.
Old 05-20-2008, 10:23 AM
yota4life6's Avatar
Thanks to both of you above!! That helps.. Can anyone tell me their opinion on the 3.4 vs. the 3.0 3vz? Is the 3.4 more bullet proof with less HG problems? Could use some more power, so will def consider it.. Any idea how much the plug and play wiring costs that I would need for this job?
thanks again...this site rules!!!!!!!!!
Old 05-20-2008, 10:28 AM
NicCantDecide's Avatar
There's an entire forum dedicated to 3.4 swaps, all the information is there.
Old 05-20-2008, 11:35 AM
Noltz's Avatar
The 3vze, with it's many problems, is still a pretty dependable little engine. With the cost of 3.4's coming down (given the price of fuel driving down the resale of SUVs, thus more are becomming scrap), I would go the well-beaten path and find a 3.4. They're more powerful, better mileage, and none of the HG problems that plague the 3VZE.
Old 05-20-2008, 11:46 AM
norcalsvx's Avatar
3.4l is a much better motor search up in the 3.4l swaps forums here
Old 05-20-2008, 12:49 PM
Elvota's Avatar
https://www.yotatech.com/forums/f160/
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
Quick Reply: engine swap!!??
