| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Engine Surges on '88 P/U 22RE when a/c is on and brakes are applied at a stop (Idle)
#2 (permalink) |
Do what I did.
Unhook your brake booster and plug the vacumn line. See if the problem is still there. If it is, your booster is bad. Mine only does it when I really step on the pedal hard, but it does it enough I know I have to replace the booster.
__________________
Life is too short to have to work.... RIP - 4 July 2008 - '88 4Runner, Audiovox Cruise Control,Valvoline Full Synthetic Gear oil, SR5 instrument cluster, '95 4Runner Seats, Rear U-bolt Flip
#3 (permalink) |
Here is another thread from IH8MUD where some of us have a similar problem.
__________________
Click here to buy rock crawling stickers and shirts |
#4 (permalink) |
Mine did it and after a day at the toyota dealership all it was was a screw on top near the throttle body at the air filter tube needed to be screwwd in all the way. Some how it lossened up. At first we thought it was a booster but $30.00 later and feeling like an idiot it was just the screw had loosened up.
#5 (permalink) |
What screw exactly are you talking about? I know that there is the idle adjustment screw and the a/c idle adjustment screw(the big black screw with a spring around it located just off the intake manifold) is there another screw?
#6 (permalink) |
NO not the black plastic screw. It is directly on top where the air filter tube joins the throttle body. It's right on top and it set below flush when it screwed in. I wish I could do a picture I would show you. It is all metal. I am going to look it up in the manual I have and see if it has a name.
#7 (permalink) |
I think you are talking about the idle adjustment screw......I don't think that is the problem.
#8 (permalink) |
Its not listed as the idle adjustment in the manual. It is on top to the left near the clamp on the hose on the throttle body. In the manual it doesnt explain what the screw is. I wish I could copy the picture and post but cant. The picture is in a haynes manual I have and the screw is there. I will swing by the Toyota dealership where I was looking like a fool after the adjusment to see if he can help with the name of the screw.
#10 (permalink) | |
Quote:
I went and chenged my oil today and went looking at this today. In doing so, I found this screw to be loose too. I took it out, counting the turns and cleaned it up. Noticed the o-ring on it was quite flat and stiff and it is now planned on being replaced once I can get the correct o-ring. Doesn't take much of a turn on that screw to change your idle in a big way. So does anyone know what this screw if for? It appears to control the air flow through the large hose under it. I didn't follow it today as I wanted to get in and out of the garage rather quickly this afternoon.
__________________
| Tags |
| 22re, engine, surge |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| truck idles at 1600 and surges when the brakes are applied. | shugashaft | 86-95 Trucks & 4Runners | 8 | 06-05-2007 06:44 PM |
| idle surges up and down | kev109 | 86-95 Trucks & 4Runners | 2 | 04-23-2007 07:25 PM |
| Brakes applied=up and down idle | ttr125mar | 86-95 Trucks & 4Runners | 8 | 05-11-2006 06:28 AM |
| 88 V-6 :: Hunting Idle while on brakes | breesej | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 11-29-2004 10:15 AM |
| Idle crash when brakes are applied ?? | PirateFins | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-29-2003 09:54 AM |
