engine help
Old 05-19-2008, 03:19 PM
hgpilot's Avatar
engine help
have a 1993 truck 22re, 185,000 miles, compression starting from the front cylinder working back is 150, 145, 160, 145, my brother says its not bad, a friend says he would rebuild, the truck leaks oil bad, so get a new engine or just replace all seals, any help would be great, Dave
Old 05-19-2008, 03:23 PM
abecedarian's Avatar
compression's not bad... not good, but not bad.
where's the oil leaks at? The front crank seal isn't too hard to do, the rear means pulling the trans. valve cover gasket is real easy to do.
Old 05-19-2008, 03:33 PM
hgpilot's Avatar
it's leaking from the rear seal
Old 05-19-2008, 03:44 PM
84sr5yoty's Avatar
Adjust your valves and recheck compression. Valves that are too tight or too loose have a very big effect on compression readings.
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: engine help
