Electric fan to mechanical
How do you convert from electric fan back to a mechanical fan. Previous owner installed a electric fan and it stopped working. This is causing my 3.0 to get hot, like almost at the red hot, and we all know 3.0s don't like heat.
Or if anyone knows a simple fix to them not turning on let me know, I replaced the relay and it still doesn't work, the fuse is also good
The relay was already on the car, I just replaced it. I'll check to see if its getting power, it should because the fuse isnt blown out
So basically I need help to wire this thing to always run with the ignition on. Im clueless about wiring
Yes it is getting power so what I did was I disconnected the two wires from the temp sensor and connected them to each other so the fan will run if the ignition is on.
I connected the battery back on, turn the key and my heart skipped a couple beats IT TURNED ON!!!! So that's a temporary fix until I can get a new temp sensor
It is what came with the flex a lite kit I'm assuming, the previous owner did the swap but it is a switch near the radiator with a little probe thing u stick inbetween the fins of the radiator
It might, try it out. The one on my v6 isn't a massive fan. But I know a lot of people do the mercury/Lincoln or Taurus electric fan swap, so look into that as well
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
