EGR removal
Old 08-30-2009, 06:12 PM
yoterr's Avatar
EGR removal
oook, so ive searched and searched only to end up with egr removal on 22RE's or people who got talked into keeping it, or really no info at all, but the P.O put block off plates on the exhaust manifold, so i went ahead and ordered the egr block off kit from LCE got those on and i removed all the egr stuff including the metal vac lines, im pretty sure i got the vac lines messed up and it idles reallly high like 1500 2000 range, moved some stuff around got it to idle down to 1000, does anyone have any pics of their vac lines set up without the EGR stuff??? i went by kyle22R diagram for an 83 canada model and thats what got it idled high....so im lost, help me yotatechers
edit: i figured it out scroll to bottom...
Old 08-30-2009, 06:50 PM
abecedarian's Avatar
what block off plates on the exhaust manifold from the PO?
EGR doesn't go through the exhaust manifold.
Got pics?
Old 08-30-2009, 07:40 PM
yoterr's Avatar
the two tubes the come from the exhaust mani,
Old 08-30-2009, 07:51 PM
oh, the PAIR (fresh air to the converter) manifold?
Old 08-30-2009, 07:58 PM
PAIR (Pulsed Air-Injection/Reaction) is completely separate from EGR (Exhaust Gas Recirculation).
PAIR brings fresh air from the air filter and injects it into the exhaust stream at the exhaust ports on the manifold.
EGR takes exhaust gasses, routes them internally, through the head, and injects them in to the intake manifold.
Old 08-31-2009, 05:05 PM
yoterr's Avatar
ahh ic, good to know, but he still had the tube that goes from the head to the intake undone and some home made block plates on, i dont think it worked anyway and besides its all off now..
Old 08-31-2009, 05:14 PM
got pics?
on the 22re, all you have to do to bypass EGR is block the passage from the EGR valve to the back of the intake manifold... and you can do that with a little piece cut out of a soda can.
Doing that may cause higher cylinder head and exhaust temps on longer, constant speed trips, which may in turn cause lean mixture codes to be thrown even on non-cali vehicles.
Some vehicles might throw a CEL for EGR temp (mainly California models), though.
Old 08-31-2009, 05:24 PM
yoterr's Avatar
well i gots the good ole 22R no E in it and i took all of it off already and bent up the steel vac lines to get em out... so no egr going back in....ill get some pics up here in a min or two
Old 08-31-2009, 05:40 PM
yoterr's Avatar
heres the drivers side
then the pass
and another pass further out
Old 08-31-2009, 06:41 PM
yoterr's Avatar
bahh no 1 els knows....i know good few of you have done this, all i need is maybe an ms paint on my pics of where to put the vac lines and what ones to cap off, or a pics of your setup would be cool!!
Old 09-01-2009, 02:57 PM
yoterr's Avatar
bumpidy
Old 09-01-2009, 04:18 PM
yoterr's Avatar
well for any1 els who wants to know i figured out the Vac line deal, or at least the way i have it setup and its working so, i drew up a crude ms paint to show what i did
Old 09-01-2009, 06:01 PM
thadlinkwent's Avatar
Lol crude, but it works. Glad u got that figured out, gets me off the hook for following my lines for yah.
As long as it works. Does this do anything for yah performance wise? I don't really see how it would, but I'm just curious.
Old 09-02-2009, 07:51 AM
yoterr's Avatar
meh not really just cleans up the engine bay quite a bit from all the vac line clutter but i cant say anything for performance cuz it was blocked to begin with i just took all the stuff off....and thanks to the super mod who fixed the title
Blamalam
03-12-2022 07:34 AM
Colington
08-13-2015 02:21 PM
e_richard
07-30-2015 06:50 PM
montanatruck
07-25-2015 03:45 AM
Snort
07-09-2015 03:58 PM
Quick Reply: EGR removal
