ECU burned up - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-18-2008, 12:45 PM   #1 (permalink)
Crawdad's Avatar
ECU burned up
The magic smoke came out of my 4runner's ECU today - I was in the woods, and the A/T Oil Temp, Battery, and Brake lights all came on. Battery gauge was about halfway. It died, and wouldn't crank, so I had a buddy jump it. It jumped fine, and ran for about a minute before the dash lights came back on. I tried to get it turned around and back out of the woods, but the idle started going funky (up and down up and down) and it died.
This time when it died, none of the interior lights would come on, and it wouldn't do anything when you tried to crank it. We pulled the underhood fuse panel, and noticed that the alternator fuse was blown, as was the EFI fuse. We jumped these two fuses with wire, and it would turn over, but not crank, and then the ECU let out a wonderful puff of smoke.
I'm sure I fried my ecu, so I just bought one from ebay. ANy other ideas?
__________________
1990 4Runner 3.0/AT/4WD - 285/75/16 TreadWright D-Muds, SDORI Coil Spacer, Aisin Hubs
2005 Mazda 6i 2.3/MT
Crawdad is offline
Old 05-18-2008, 12:48 PM   #2 (permalink)
CJM
CJM's Avatar
Sounds like your alt took a dump and by jumping those fuses you fried the stuff well.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 05-18-2008, 12:53 PM   #3 (permalink)
abecedarian's Avatar
Quote:
x2
either the regulator went, or the diodes
__________________
Insomnia: it's a way of life.
Ever notice "tupac" spelled backwards is "caput"?
Meet me on Zune.
abecedarian is offline
Old 05-18-2008, 01:42 PM   #4 (permalink)
Crawdad's Avatar
Yeah, by the time the well-meaning guys I was with pulled out wire and started jumping fuses, it was too late for me to stop them.
Oh well. I just replaced all the fuses but the alt fuse, and everything works. The engine will crank and crank and crank but won't turn over - sound like the ECU?
How can I test to find out if it is the alternator, the diodes, or the voltage regulator? Or do I need to wait until I replace the ECU?
__________________
Crawdad is offline
Old 05-18-2008, 02:13 PM   #5 (permalink)
the only safe way to test the alternator would be to take it down to a shop and have it bench tested.
if you know someone with a compatible ECU, you could try swapping them.
__________________
Meet me on Zune.
Old 05-18-2008, 02:16 PM   #6 (permalink)
CJM
CJM's Avatar
Listen for the fuel pump to come on and see if you hear it. Hear it its not that, dont hear it the trucks not getting fuel due to the EFI fuse.
I would also check the AFM sensor and see if thats shot, will cause the same issue. Also try and swap ECUs with someone..
__________________
CJM is offline
Old 05-18-2008, 03:08 PM   #7 (permalink)
Crawdad's Avatar
I'll check the fuel pump, the EFI fuse isn't blowing anymore, I replaced all the fuses but the 80A alternator fuse, and went ahead and jumped the alt fuse with an inline 50A fuse (That didn't blow). With the alt fuse jumped, the truck cranks, all the interior stuff works, it just won't fire. The smoke came directly from the ECU, so I'm pretty sure it's dead. Where is the AFM sensor located?
My father in law has a 1990 4runner but his (and his ECU) are 5spd and won't hook up from what he says.
I found and bought as 1990 3VZE A/T ECU from ebay for around $100. None of the local junkyards had anything.
Here's what I think happened: the alternator died, popped the Alternator fuse under the hood, which killed power to the interior of the car. While trying to jump blown fuses to get it to start, my well-meaning buddies accidently jumped 12v from the ALT to the EFI fuse under the hood, making the magic smoke leak out of the ECU. I should be mad, but there ain't nothing I can do about it, I reckon.
Where can I get that special 80A fuse that goes in the alternator slot under the hood?
__________________
Crawdad is offline
Old 05-18-2008, 03:40 PM   #8 (permalink)
CJM
CJM's Avatar
The AFM is an air flow meter iirc and is mounted right at the airbox, it measures airflow. If it dont work the truck wont run.
__________________
CJM is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
burned up 85 pu with sold axle what do you think toy89yota 86-95 Trucks & 4Runners 29 10-31-2007 03:58 PM
Burned valve diagnosis alankenji_84 86-95 Trucks & 4Runners 14 01-22-2007 07:22 PM
Bulb keeps getting burned-out TEPUI 95.5-2004 Tacomas & 96-2002 4Runners 7 01-15-2007 09:03 AM
Audio burned to DVD? jct61765 Computer Talk 6 07-18-2006 04:57 AM
College: Who is already getting burned out? SLC Punk Off Topic Talk 17 09-19-2003 04:38 PM
2009 InternetBrands, Inc.
