Ebrake Issues
Ebrake Issues
So I took the wheels off my 87 4runner and took off the brake drum and all hell broke loose. The ebrake cable that I thought was broken is intact and works...but when you pull the ebrake nothing...there are two metal arms with hooks in the brake assembly that look like they should be attached somehow but they are an inch or so apart...the upper arm that is attached to the brake cable works perfectly and the lower arm will not budge...I am wondering if the two arms should be attached or what...any help is much appreciated. Also...when I took the drum off there was grease everywhere! I am hoping that the breather is just plugged but we will see.
Thanks
Thanks
crammit442
7
11-29-2017 12:30 PM
rjtrials
08-06-2015 07:25 PM
Luvmeye22re
08-04-2015 03:53 PM
