| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||||
early vs late idler arms?
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#2 (permalink) | |
or, is it possible to upgrade a stock idler to the stronger style?
like me with my 90?
__________________
Trailer Re-Build - Check it out!!! Quote:
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack |
#3 (permalink) | ||
I don't think the later idler arm is really much stronger, maybe something like 5% stronger, I don't know, whereas the brace/gusset is maybe 100% stronger.
__________________
#4 (permalink) |
The diameter of the idler rod (haha...rod) is bigger then the 91 and prior units.
My downey idler arm brace was for a 1993 idler arm (I got the arm too) and it fit fine on my 91 arm..
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#5 (permalink) | |
goot to know, thanks jay...
__________________
1990 4RUNNER
#6 (permalink) | ||
There are two part number, on for each idler arm, which is confusing me.
__________________
#7 (permalink) |
2wd and 4wd?
__________________
#8 (permalink) | ||
No, don't think so, good guess though.
http://www.downeyoff-road.com/Suspen...s/1986-95.html ![]() Steering idler arm gusset Downey invented the Idler Arm Gusset; it is no more than another remedy for another problem. As we discover what can be bent or broken, we produce the bullet proofing. Most cases of bent idler arms are found on Toyota’s with 4 inch lift kits, but occasionally we find a bent Idler Arm on a Toyota less radically equipped, but more radically used off road. The idler Gusset is a simple bolt-on device, silver powder painted for lasting durability. 45486 86-92 4WD Gusset $49.95 45493 93-95 4WD Gusset $49.95
__________________
Quote:
More info on 4Runners Last edited by Matt16; 12-28-2008 at 12:08 AM. |
#9 (permalink) |
I would have sold you my later idler arm already with brass bushings, grease fitting and a downey brace on it since I'm sas'd now
__________________
1993 Pickup Aussies front/rear 5.29's SAS 85 axle trussed and gussetted w/ HP third 30 spline longfields Trailgear IFS Eliminator 5"HD springs Rear 4" springs 37"x13" Boggers 4crawler 1" body lift Snorkel Warn Rockcrawler bumper Smittybilt rear bumper with some major reinforcing and recovery points 4xinnovations tube doors Champion 7500lb winch 2.5" Magnaflow exhaust Stacked through the bed |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE: Early to late intake swap | elvis | 86-95 Trucks & 4Runners | 3 | 12-27-2007 11:29 AM |
| Early versus Late 3vze Heads | KempLN3R | 86-95 Trucks & 4Runners | 2 | 06-13-2006 09:32 AM |
| Downey idler gusset fits spicer idler arms. | Mikronized | 86-95 Trucks & 4Runners | 1 | 01-10-2006 03:50 PM |
| So Cal Trip Late Early September???? | deathrunner | Off Road Trip Planning, Expeditions, Trips, & Events | 19 | 07-16-2004 10:26 PM |
| New Late Model IFS Lift/Arms/Stuff | Flygtenstein | Offroad Tech | 3 | 02-07-2004 06:52 AM |
