Dur, what's this wire do?
Old 08-23-2011, 05:57 PM
Tower0fPower's Avatar
Tried installing a subwoofer and replacing all the factory speakers in the runner today. Hit some hiccups...
Problem #1: Basically there's no power to the rear speakers, wtf mate? Rear speakers as in the ones in the cargo bay that are enclosed in a black plastic vented box and amplified from within the box.
Problem #2: Possibly related to Problem #1.. This wire (see attached photographic evidence!) has no home! There is no receptor for this connector. No yin to this yang. I are wondering if it is a remote wire for the amplifiers in the rear speaker boxes?
Old 08-23-2011, 06:21 PM
Oh yea! 1995 4Runner SR5 3.0 4x4 yada yada
Old 08-23-2011, 06:29 PM
irab88's Avatar
white with a green stripe, seems to me, to be a ground. try jumping it to ground and see what happens. if you see a lot of sparks, that's not a ground
Old 08-23-2011, 06:47 PM
mwc0404's Avatar
may be the either the positive or negative for the rear speaker, probably the negative.
Old 08-23-2011, 07:06 PM
totally a bro
Staff
vital22re's Avatar
bypass the factory amp.
Old 08-23-2011, 07:07 PM
I'm thinking tomorrow I'll find a nice bare spot of metal and see if I can get some sparks to fly and then have fun tracking down that illusive blown fuse. Thanks for suggestion!
I don't believe it's a speaker wire as those are all accounted for and already spliced into my wiring harness. But it's possible, I'll re-recheck my wiring tomorrow morning.
Old 08-23-2011, 07:15 PM
yotarover's Avatar
pwr supply back up
Old 08-23-2011, 07:16 PM
yotarover's Avatar
my 86 came with a factory working radio ( tape player) took it out. diagram said that lil clip was for the power supply backup
dont think it's changed to much, was the same in my 89 as well
Old 08-23-2011, 07:29 PM
What exactly is a power supply backup? Is that just a secondary 12V wire that is hot when the ignition is on then?
Old 08-23-2011, 07:34 PM
totally a bro
Staff
vital22re's Avatar
86 and 95 are two waaaaaaaaaaay different years.
Old 08-23-2011, 07:37 PM
Do you know the output on the factory amps? If they exceed my headunit I might as well integrate them, but if they don't then I can see value in bypassing them.
Old 08-23-2011, 07:54 PM
totally a bro
Staff
vital22re's Avatar
they do not.. remember.. they were "banging" in 1995... its 2011 now... any stereo shop will bypass the factory amp as its not worth a darn.. Your new head unit over powers it.
Old 08-23-2011, 08:22 PM
That's probably true, and I've already removed the front factory amplifier so it would be unbalanced to have the rears amplified from the factory. Kind of an empty victory now that I'll be bypassing them but I just figured out how to integrate the rear speakers...
After some keen searching I discovered that the rear speaker amplifiers are triggered by the power antenna which is only powered when the radio is on, not when I am trying to listen to my iPod... The workaround is to connect the remote amplifier wire (essentially an ignition wire) from the headunit to the power antenna wire (the blue wire in the harness.)
As far as that other green/white wire goes I'm still stumped unless it truly is the power supply backup. In which case I'm still not sure what its purpose is
Old 08-23-2011, 08:47 PM
totally a bro
Staff
vital22re's Avatar
grab a multimeter and test it.
Old 08-24-2011, 12:44 AM
TNRabbit's Avatar
pwr supply back up
I'm pretty sure that's it--unless it's plugs into the cigarette lighter~
Provides power constantly so you don't lose your radio settings.
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
ToyoToler
08-08-2015 08:43 AM
Daneums
07-28-2015 11:57 AM
TDonkey
07-26-2015 10:14 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: Dur, what's this wire do?
