Dual cases and T-case brake? how?
Old 07-16-2009, 04:58 PM
drew303's Avatar
So...
how does everyone get their stock parking brake cables to work with a dual case setup and a Transfer case brake?....
Old 07-19-2009, 10:45 PM
drew303's Avatar
bumpity bump...
No one's put a Tcase brake on a dual case setup?
I got my ideas on how to make it work, it's doable I think but definetly like to see some pics of other peoples "ideas" in action!
Old 07-19-2009, 11:50 PM
NYChopshop's Avatar
this should work: http://locktup4x4.com.au/hilux-solid...brake-245.html
only thing is I'd be a little worried about the mounting locations snapping off.
If you have any plans to do a solid axle swap, this would be the best deal for you I think: http://www.allprooffroad.com/pickupd...ickuptcase/360
That thing will apparently interfere with the whole torsion bar front suspension dealie, tho. I'm not sure if a coil over independent front suspension would interfere or not, but the x-member is designed for a SAS.
Oh, and there is this one too, although I don't see anything in specific about dual cases: http://www.allprooffroad.com/9095brakeupgrades/33
Old 07-20-2009, 05:55 AM
waskillywabbit's Avatar
85 ext cab 5" lift, 1" body lift, 35s, dual cases twin stick with AP e-brake kit
Just bolt it all up and adjust. Nothing to it.
What's the issue?
Old 07-20-2009, 10:01 AM
NYChopshop's Avatar
does the double transfer case with the e-brake mod need additional support from a special crossmember, or is that just my incorrect impression?
Old 07-20-2009, 10:10 AM
Red_Chili's Avatar
When in double low the torque under load can cause some WICKED driveline twisting. There are a number of solutions for that these days, from modified tcase mounts (Marlin) to new rear crossmembers (FRORF, Marlin, AllPro, yadda...).
I used a FRORF crossmember and modified AllPro tcase ebrake (primarily longer bolts to ensure enough thread engagement in the tcase cases). It works fine... but NOT as well as the stock ebrake setup. You could actually stop the truck when in motion down the highway with the stocker... not so, with the tcase ebrake.
And of course if anything breaks such that the tcase is disconnected from the wheels... you have no ebrake (such as... 'friends' finding it humorous unlocking the hubs on your rear axle, given a full floater and locking hub arrangement...)
priest16
15
08-06-2015 07:43 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
89hilux1
07-19-2015 01:32 AM
crashburnoveride
07-10-2015 06:39 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Dual cases and T-case brake? how?
