Driver side window goes up but not down
Old 01-05-2011, 09:11 AM
Tanker5503's Avatar
its a 88 4runner SR5 and whenever i press down on my window switch it does nothing not even a sound then i press up and it dims the lights on my dash and i can hear it working. I put power directly to the motor and goes up and down. With a Test light i tested the plug that the motor gets power from and used the switch up and down and it seem to get power both ways going up and down. Any other test so i can narrow it down to what it is. Thanks! My passenger window works fine from both switches to.
Old 01-05-2011, 09:18 AM
rustyf99's Avatar
I fought the same problem for months - it's the switch. Took mine apart, tried to diagnose it, cleaned the switches, sometimes it would work, sometimes not... just replace the switch and call it a day!
Old 01-05-2011, 10:48 AM
BeMiceElf's Avatar
On my 86 pickup the same thing would happen. I would just take the switch out and clean the buildup off. Then it would work again.
Old 01-05-2011, 10:03 PM
Tanker5503's Avatar
ill check out the switch more closely tomorrow and see what it is. What is the best way to clean out the switch i've taken it out but haven't really gotten into it.
Old 01-20-2011, 04:44 PM
twhite's Avatar
http://www.4crawler.com/4x4/CheapTri...l#WindowSwitch
This may help you.
coreyedwards7611
01-16-2016 06:38 PM
thefishguy77
07-30-2015 10:59 AM
msane99
07-17-2015 10:13 AM
razorman8669
07-12-2015 12:13 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Driver side window goes up but not down
