Driveline Lubrication
Old 11-10-2008, 09:00 AM
kmat123's Avatar
I have had my '94 Toyota pickup for the past 6 years and have put just over 50K miles on it. In that time I have only lubricated the drive-line once or twice. I am in the process of changing out my tranny, differential and T-case fluids and thought I might as well lubricate the driveline too before the weather gets nasty this winter. My question (albeight a stupid one) is how do you know when to stop pumping grease into the u-joint and slip yoke zerks? Also, I know that Toyota recommends using both a moly or lithium grease depending on the joint but historically I have just used a moly grease for all the joints...is this ok? Thanks!
Old 11-10-2008, 11:06 AM
justcuz's Avatar
Lube
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
I used this as a guide when I first got my truck.
Old 11-10-2008, 11:47 AM
22mr2's Avatar
Personal preference for me is synthetic grease, it seems to work better in colder weather.
ktm192k
10-01-2015 08:47 AM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
Odin
09-24-2015 04:38 AM
djpg2000
09-07-2015 10:36 AM
Quick Reply: Driveline Lubrication
