does anyone have any tips on painting frames
Old Nov 13, 2007 | 12:58 PM
89pickupsr5's Avatar
Question does anyone have any tips on painting frames
Old Nov 13, 2007 | 01:00 PM
Tacoma750's Avatar
i usually rinse everything off real good, and hit it wit h a degreaser/scotchbright pad. CLean it off again real nice and flat black it.
Old Nov 13, 2007 | 01:01 PM
ydopen's Avatar
Take off the bed and wheels also
Old Nov 13, 2007 | 01:03 PM
Tacoma750's Avatar
What^? Yuo dont ahve to do that. I have abodylift so it made it easier to get to everything. But you dont have to remove anything...unless your going for a candy apple red show frame ;-) But if its just a DD/wheeler and your looking to protect form rust..do as i said.
Old Nov 13, 2007 | 01:07 PM
ydopen's Avatar
Depends on how much time u want to spend on it. I just get carried away
Old Nov 13, 2007 | 01:11 PM
i already have everything off of the back and pretty much all of it down to the bare metal i was more wondering what kind of paint to use how many coats and since i'm not taking the cab off some kind of undercoat spray? thanks preciate it
Old Nov 13, 2007 | 01:14 PM
ydopen's Avatar
Once again how carried away do you want to get I'm sure your local body shop supplier can leaved u in the right direction
Old Nov 13, 2007 | 01:16 PM
Tacoma750's Avatar
You can primer it and flat black it..
You can spray herculiner on it
You can por15 it
Old Nov 13, 2007 | 01:18 PM
ydopen's Avatar
You can por15 it
x2
Old Nov 13, 2007 | 01:21 PM
Jay351's Avatar
I just cleaned mine off a bit and hit it with gloss black tremclad/rustolium.
I didnt really prep it very well. I love the glossy look, but I did the skids in flat black.
Old Nov 13, 2007 | 04:06 PM
nate V's Avatar
Oil undercoat it and dont waste your time painting it...
Oil undercoat your truck with tractor hydraulic fluid ...thats what i do
PS anyone need their truck coated...????
Old Nov 13, 2007 | 04:28 PM
rdlsz24's Avatar
That sounds like a hell of a mess lol
Rob
Old Nov 13, 2007 | 04:38 PM
superscreenname's Avatar
Glossy paint is more durable and things won't stick to it as easily. I like 3 coats personally.
Albert.G's Avatar
lol just make sure your in someone elses driveway
Old Nov 13, 2007 | 04:45 PM
CJM's Avatar
CJM
Degrease and clean it, paint with flat black or satin black rustoleum, 2 coats.. I just spray away really..
Old Nov 13, 2007 | 04:53 PM
crolison's Avatar
You can do it in mine, my parents don't care at all. I spray paint so much in my driveway its not even funny. From a physics project i have 5 meter intervals sprayed out.
I think i am going to coat my frame with some rust stop, then go over with rustoleum.
Old Nov 13, 2007 | 04:56 PM
Albert.G's Avatar
lol hey me and you both, ive got red paint from my integra, white paint from my bmx, black paint from the passatt, and bedliner everywhere from my truck lol
Old Nov 13, 2007 | 05:12 PM
Rob88's Avatar
hey man personally i would just clean it all off with some degreaser( chemtool) and then scuff it up with some steel wool.. Then go to your local auto parts store and by some underlining and spray it with that. That way it is nice and black and tough.
Old Nov 13, 2007 | 05:44 PM
nate V's Avatar
Its not that messy considering the corrosion it prevents
living up here in the rust belt area paint just doesn't cut it
Old Nov 13, 2007 | 06:58 PM
82yota's Avatar
I will second the spray it all with oil and forget about paint. Its the only way to help keep rust down. Maybe where there isn't winter for 5 months and snow and salt and ice for 5 months it wouldn't be bad but if I paint my box gloss black rustolium in the fall with a brush heavy and by the time spring rolls around half of it is gone and rust is in its place. Spraying the inside and outside of your frame, and panels is the best way to keep it rust free. Undercoating will only hide the rust and when it shows up it will be too late. As most of us know the frames rust from the inside out so painting the oilside of the frame really wont do that much anyways other than make it look pretty. What you should do every spring after the salt is gone is get that hose right inside the frame rail and get the truck on an angle and hose it right out. You would be suprised at how much rust comes out. Then after you did that and have let it dry out spray it full of oil and put the plugs on. I do an oil change in the fall before winter starts and spray all my used oil inside my frame and fenders with a cheap oil gun I bought for $10. Works well but the oil must be warm to flow through the gun.
