DIY headlight harness keeps blowing RH headlight fuse
Old 10-13-2012, 07:55 PM
bend's Avatar
So I am using bleeder's schematic
And I keep blowing the original 10 amp fuse. If I dont ground the plug, it wont blow but I still am not getting any light. This is the headlight plug that I am using them to trip the relays. I confirmed the high and low wires are going to pin 86. Anyone have a guess as to what is going on? I dont see why the fuse would trip if it has an outlet and is properly grounded. I have tried not grounding that plug and it still doesnt work. All of the grounds are on bare metal. I plugged the old headlights and they work.
So I did some more testing and there is no voltage coming from the old plug when I dont have it grounded. If i do ground it then it just blows the fuse.
Old 10-14-2012, 03:50 PM
bend's Avatar
Found the solution. I should have read the DIY thread in depth. Just connect the common and the grounds from the relays. They are no longer grounding. I think my sitch is still crap though because my highs dont work.
MO transplant
04-23-2023 11:58 AM
theking11863
03-19-2016 09:36 PM
Mrhoadley
08-04-2015 06:08 PM
Esibnitsud
07-30-2015 08:19 PM
rushw
07-18-2015 01:46 PM
Quick Reply: DIY headlight harness keeps blowing RH headlight fuse
