Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Distributor fire
First off I have a '88 4x4 pickup with a 3.0 and 5 speed. I was wondering if anyone with a 3.0 has ever had thier distributor cap catch on fire? The reason I ask is I parked my truck today and noticed a few minutles later smoke was coming from under the hood and I found my cap on fire! I put it out and replaced it and the spark plug wires and rotor switch and now the truck seems to run fine but I am concerned because I have never seen this happen before. Any suggestiond on what could have happened and any way to fixx it would be greatly appreciated!
| Sponsored Links |
#2 (permalink) |
wow, i will say thats a new one for me... never heard of that.
__________________
Cory Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here 04 Dodge 2500 Cummins - DD/Tow Rig 02 Z06 Corvette - Weekender 94 FZJ80 - Wheelin Rig. Currently on 33"s, plan to go 35"s. 72 Buick GS - i.e. the project that will never get done. |
#3 (permalink) |
No body has that is what is blowing my mind! I even went today and talked to a couple of mechanics and they told me that they had never heard of such a thing happening!
__________________
1988 Pickup 4x4- 3.0,5 speed, 32x10.50 Super swamper, 15x10 Eagle wheels, Torsion crank, Skyjacker shocks(front), rear blocks, Edelbrok IAS shocks(rear), 7500 lbs winch,custom front and rear bumper |
#4 (permalink) |
Is it possible that fuel or chemicals were spilled on the cap and seep under it?
#5 (permalink) |
thats my guess...
__________________
#6 (permalink) |
dist cap fire
Ok i think i know your answear. your cap was "stolen" off another 3.0 so that would make it a (HOT CAP) J.P I have never seen or heard of this happening before .like someone above said it must of got oil or poss fuel on it to make it flame up.
__________________
))LIVIN HARD & DIRTY(( Yota 4x4 "Well ya could be starting off wrong by calling her a "bitch" See the TOYOTA gurl deserves respect.Call her by name or give her one.Once in awhile patt her on the d(ass)h.Be good to her & she'll be good to you." K-THANKS Last edited by TOYZILLA : 02-08-2007 at 09:01 PM. |
#7 (permalink) |
I don't know how any thing could have got in it, but it could have happened. Right now though the truck doesn't have any leaks and I ahven't sprayed anything under the hood but I really don't know but the chemical idea is the best any one has come up with and it is running like a champ now so I guess that is good enough for me.
__________________
#8 (permalink) |
if the wires were arcing across the cap got hot and burned??? but ya think ya would have had a poor running truck
#9 (permalink) |
any pics of the cap?
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
#10 (permalink) |
I've only heard of distributor fires when folks spray WD-40 in it "to get the water out" and then put it back together and immediately start the engine. Keep an eye on it!
#11 (permalink) |
![]() THis is what the cap and wires look like now. Keith B. I've only heard of distributor fires when folks spray WD-40 in it "to get the water out" and then put it back together and immediately start the engine. Keep an eye on it! I wa told the same thing the only thing is that I had sprayed nothing in it and as a matter of fact had been driving it all morning until this happened.
__________________
#12 (permalink) |
My dist cap burnt yesterday. I was driving and the engine stopped. I couldn't start it again, and saw smoke coming from under the hood. I had new dist cap, new rotor and new wires.
#13 (permalink) |
could the caps be burning due to inferior materals, cheap cap?? my cap and rotor come from toy dealer, this just seems so weird something breaking down and being ignited im no guru but ive never heard of dist cap letting the smoke out
#14 (permalink) |
Were these OEM caps?
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#15 (permalink) |
ChickenLover Were these OEM caps ?
Yes as far as I know it was I just bought the truck so I can't be for sure
__________________
#16 (permalink) |
Mine was not original, but still from Japan.
#17 (permalink) |
dist fire
Carbon tracks on the inside top of dist. will /can arc....saw it on a Camaro I had....they were numerous..suprised the engine even started
![]() Last edited by bruizer : 02-11-2007 at 05:41 AM. |
#18 (permalink) |
I want to see pix of that vehicle on you're avatar....
#19 (permalink) |
I ment cap and rotor. I'll get some pics on monday.
#20 (permalink) |
I've seen caps rotors and wires get pretty burnt up from resistance related heat. I've never actually seen or heard of one flaming up though.
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam, 295cc injctrs, Supra AFM, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
#21 (permalink) |
bringin this thread back but , yea my 89 had the same thing happen. I was just late getting there and lost a bunch of stuff due to fire damage. Mine had a cheap(new) cap,rotor, and wires on it with less the 150 miles on them!!!!
#22 (permalink) |
I actually just posted about a simliar occurence. I have had the distributor caps and rotors melt to the point the truck won't run, only the first was genuine toyota, so I have seen generic and brand name melt. No clear reason as to the cause.
