Disabling DRL on 2nd Gen. 4runner
if you want to disconnect your DRL's on your 91 4Runner, under your ashtray infront of your shift there is a cover, take it off. behind the cover you should see a grey box, take it out with wires still connected. cut the black with orange wire going into the box. CONGRADULATIONS you just disconnected your DRL's for a 1990/1991 4Runner.
actually, if u take teh cover infront of the shifter off, it's the yellow with black wire, if i recall correctly... it's in the end/corner of the plug to the gray box... trim that wire, and ur DRLs will nolonger work...
06-01-2021 01:51 PM
Steezy96yota
07-06-2015 10:00 AM
