Difference between 1988 vs. 1989 4runner leaf springs?
Old 05-20-2007, 07:27 PM
vmax84's Avatar
Need to bump the rear end up on my 89 4runner, but JCWhitney doesn't offer them for the 89 4runner. However, they do offer them for the 84-88 4runner.
What's the differnece between the 84-88 vs. 89 4runner leaf springs? Thanks.
http://www.jcwhitney.com/autoparts/I...26531710257017
vmax84
Old 05-20-2007, 07:43 PM
mtnfreak's Avatar
No difference.
Most parts suppliers just take the Truck parts list and re-label it as a 4Runner parts list. None of them have done any research, otherwise they would know that the trucks changed body styles in 89.5 and the 4Runners changed in 90. I've learned to just ask for parts for an 88 4Runner. 99.9% of the time you'll be fine. Getting parts for an 89 truck pulls that average down to about 60%.
FYI - I reccomend the Rancho Soft-Ride AAL's. Work great for me.
Old 05-20-2007, 07:55 PM
ewong's Avatar
The Rancho Soft Ride AAL (if its the one Im thinking of - take out the bottom leaf and add two leafs back) is great..
But like all AAL, the "re-arch" of the lower leafs will eventually "cut" the upper leafs via wear.... granted Im talking about 100K miles,, but it will wear them.
But then again - at 350K ... Ive gone through several mods to the suspension
Old 05-20-2007, 07:57 PM
vmax84's Avatar
No difference.
Thanks for the info. You wouldn't happen to have a link to the Rancho's, would ya? Thank you.
vmax84
Old 05-21-2007, 12:41 PM
mtnfreak's Avatar
http://www.gorancho.com/flash/rancho.html
Crappy site, I'm sorry to say. I ordered the AAL's from a local parts store.
Old 05-21-2007, 01:13 PM
Jay351's Avatar
I bought some add-a-leafs that where for an 86 pickup, (not sure if this helps) but they will work on my 91 rig. On the procomp website the parts number is the same so..
Old 05-21-2007, 05:18 PM
vmax84's Avatar
Won't the add a leafs keep the suspension from "flexing", or "traveling" like it should? Wouldn't new springs let the suspension flex like it should?
Seems like add a leafs would make the suspension stiffer.
vmax84
Old 05-21-2007, 05:24 PM
4Crawler's Avatar
A long thin add-a-leaf will flex fine, a short thick (i.e. STIFF) AAL will not flex. The Rancho Soft Ride kit includes a long, thin leaf and a shorter, slightly thicker leaf. You can mix-n-match those two leaves with the bottom leaf in your current pack to get the ride height and flex you are looking for. A buddy of mine runs those leaves (just the thin leaf for now) and they work fine:
http://www.4x4wire.com/toyota/hottoy/west/
Old 05-22-2007, 03:06 PM
vmax84's Avatar
Thanks again. Good info here.
vmax84
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
msane99
07-11-2015 08:08 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Difference between 1988 vs. 1989 4runner leaf springs?
