| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
dif. between 22re and 22rte
#2 (permalink) |
Just from reading on these forums, and others, I understand that for the turbo, the pistons are different, the head is different, and there is an extra oil line in the block. I am sure there is more to it than that, but that's coming off the top of my head.
#3 (permalink) |
the pistons are a deeper dish design, around 7.5:1 compression instead of the 22RE 9.3:1 compression. there is also an oil supply/return in the block that the 22RE doesn't have tapped out, and i think it can't be done without some major machine work(most aftermarket kits use a pressure sensor hole and drain to the oil pan).
best way to go would be to rebuild the 22RTE, maybe throw in some forged pistons and a metal head gasket...
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#4 (permalink) |
x2
__________________
1985 TURBO 4Runner 22-RTE, 33x12.5R15 MT/R's, 1 Inch Shackles, Pro-Comp ES3000's, Trail Gear Sliders, 1 inch Wheel Spacers, FJ 62 Rotors, 87 Calipers, Cobra 18WX ST II, Custom K&N FIPK, Extended Diff Breathers, Custom Rear Swing-A-Way Bumper, Load Warrior with Hi-Lift, spare tire, 4 Hella 500's, 2 Pro Comp 55's for the rear, Addicted Off Road front bumper, Smittybuilt XC8, '00 Taco Rear End w/ E-Locker. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RTE clutch/flywheel in 22RE setup???? | Yoda | General Vehicle Related Topics (Non Year Related) | 8 | 04-12-2009 07:28 PM |
| 22RTE to 22RE....how hard? | Numbchux | 86-95 Trucks & 4Runners | 11 | 05-19-2007 10:26 PM |
| 22RTE/22RE hybrid running. | dcg9381 | 86-95 Trucks & 4Runners | 34 | 12-19-2006 07:02 PM |
| Replace with 22re or 22rte?? | blkntan | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-28-2004 12:14 AM |
| 85 with 22RE, or 86 with 22RTE? | CGuava | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-12-2003 02:27 PM |
