did hg now 3.0 wont start help!!!!!
Old 04-24-2007, 11:49 AM
saleen9973's Avatar
Hey guys just did the hg and now my runner wont start. It cranks fine and i am getting spark and fuel. The problem i see is i am getting fuel in the intake and alot of it? why would this happen? what did i do wrong? is it timing i have never seen fuel in the intake before it pours out of the vaccume line that goes to the bottom of the power steering pump. by the way i have a 3.0. please help!!!!!!!!!!!!!!
Old 04-24-2007, 11:57 AM
rdharper's Avatar
Any other clues? Backfiring?
How sure are you that the timing is correct?
And the fuel is good.
(Be careful)
I believe I've read lots of stuff on this... a search is in order as well as waiting for the experts to weigh in.
Old 04-24-2007, 12:09 PM
saleen9973's Avatar
sorry i looked again and the fuel is comming out of the fuel return line the one attaches to the fuel pressure regulator. where does this line connect to?
Old 04-24-2007, 12:14 PM
rdharper's Avatar
Wow... that has gotta be good news. Probably killed your fuel pressure.
Old 04-24-2007, 02:15 PM
saleen9973's Avatar
o.k got that line fixed now it still wont start. I am getting spark and have fuel. it almost wants to start chugs a little then no go. i only have open headers and the o2 is not hooked up would this cause it not to start? i tried turning the dist 180 out and not even a pop just cranks. put it back the way it was and again it almost trys to start but nothing. please help.
Old 04-24-2007, 02:40 PM
JEBSR5's Avatar
Hook the O2 up and see what happens.
Old 04-24-2007, 02:58 PM
da_bigg_wigg's Avatar
its been asked, but... is the timing set right? once i replaced the water pump. i screwed up with the camshaft sprockets though. i had one 180 degrees to where it was supposed to be. biiig brain fart. needless to say, i won't make that mistake again...
Old 04-24-2007, 03:02 PM
TNRabbit's Avatar
If you've dumped a bunch of fuel in it, I DO NOT recommend hooking up the O2 sensor; it could ruin it. The O2 doesn't read until the engine heats up, anyway.
Are you sure you got your valve timing correct?
rpeAMP's Avatar
This may sound stupid, but last time I opened my engine up to the elements like that and loosened everything up real good, it took FOREVER to get it to turn over. Finally, after roughly 50 tries over several days, it started right up out of the blue.
Old 04-24-2007, 03:07 PM
saleen9973's Avatar
i set the timing right both dots on cam pulleys were straight up and the crank was on 0. do u think i flooded it? or maybe the dist is 180 still? I cant hook the o2 up yet because i still have to put the downey crossover on and hook up the rest of the exhaust. I was trying to start it with open headers and the o2 not hooked up. if the o2 is not hooked up will it still start?
Old 04-24-2007, 03:13 PM
1994runner's Avatar
sounds like its flooded, try holding the gas to the floor and leaving it there when cranking. before you do this make sure there is no raw fuel those open headers will ignite.
Old 04-24-2007, 03:15 PM
Elvota's Avatar
It should start with no O2. Heck, I ran mine last weekend without a O2 at all because my exhaust left the vehicle. Long story.
Anyway... I'd double and triple check that you are not 180 out with the dist. After my HG, I was 180 off and it would snort and stutter but no fire. I occasionally got a real healthy backfire and turned the dist 180. Blam... off she went.
That was just with headers installed, no O2, no cat, no muffler. Drove it up to the local exhaust shop the next morning. That sounded cool.
Old 04-24-2007, 03:16 PM
saleen9973's Avatar
one more thing i should tell you guys i dont have the pair reed valve hooked up. i bypassed it i have the downey headers and just put a metal plug on the header where the reed valve goes down to. Without the reed valve wiil it start? is this my problem?
Old 04-24-2007, 03:28 PM
Elvota's Avatar
My reed valve is gone... headers plugged... still starts and runs.
Must be something else.
Old 04-24-2007, 05:09 PM
merace19's Avatar
pull the EFI fuse and hook up the O2 sensor. Then put fuse back. I had the same problem and thats what I did to get mine running.
Old 04-24-2007, 05:48 PM
saleen9973's Avatar
i will give that a shot. anything else i can try?
Old 04-24-2007, 09:10 PM
Elvota's Avatar
What is your test that shows spark is present?
What is your test that shows fuel is present?
Not saying your wrong... just looking to verify where you currently stand.
Old 04-25-2007, 11:24 AM
saleen9973's Avatar
I pulled the coil wire off and grounded it with a screwdriver and go spark. and i pulled the line off the fuel pressure regulator and fuel wnet shooting out.
Old 04-25-2007, 01:35 PM
merace19's Avatar
Do the fix i gave you a let me know what you got. I have detailed files on the wiring and testing of the system when mine gave me the fits.
Old 04-25-2007, 01:37 PM
merace19's Avatar
see?
https://www.yotatech.com/forums/f116/will-not-start-after-head-gasket-change-112448/
Quick Reply: did hg now 3.0 wont start help!!!!!
