did a compression test today and guess what....
Old 09-02-2008, 09:14 PM
just a 22re's Avatar
my god me stupid!!!!!!!!!!!
i knew i was forgetting something when i was doing it grr well i guess when i do the new plugs ill rerent the tester and do it wot!!!!!!! my bad guys but i guess ill do it do it again and this time i might just buy the kit!! all wells i did do really good on the test though i think with the gas closed lol oopsie
Old 09-03-2008, 05:21 AM
zlathim's Avatar
I tried it both ways once when I was performing a compression test. Cranked over with the tester installed, but forgot to open the throttle up. Did it again immediately except this time it was WOT, and got a reading 10 psi higher. Granted, this was a very unscientific comparison, but it did seem to make a difference. I think that since we are really trying to see major differences between cylinder, that it is probably ok to do it with the throttle closed, as long as you are consistent. The readings may be a tad low, but if they are even, you are good. Just my $.02.
Old 09-03-2008, 09:42 AM
yeah 150psi all the way down
Old 09-03-2008, 03:19 PM
toyota-erik's Avatar
There should be a sticky on the correct procedure on a compression test.
Atleast 90% of people dont get it right. Ive even seen people pull 1 spark plug at a time.
The 3 things to remember are; 1) start with a full battery 2) pull ALL the plugs 3) WOT
someone said to put a little oil in the cylinders before starting. this is not a bad idea however, dont put too much in as this would displace air in the combustion chamber and give a false reading and possibly screw up your gauge. What I do is turn over the motor with all the plugs out until it has oil pressure.
We all know what vaccume is and how its made by our engines. So it would be logical to assume that any restriction in air flow to the cylinder would effect readings.
When you are finished, and you dont like the numbers, its time for a leakdown test. That will be covered in the next chapter.
Also, I always do mine with a cold engine.
Btw, 10% from the highest to the lowest is the rule of thumb. The static min-max depends on the engine and the compression ratio.
Old 09-03-2008, 03:29 PM
  #25
abecedarian's Avatar
lemme just through this out there-
IF you don't open the throttle, and your results pass... YOU PASS!! opening the throttle will only get you higher compression
IF you don't remove the plugs, and your results pass... YOU PASS!! removing all the plugs will only let the engine spin faster and build higher compression
IF HOWEVER YOU FAIL, YOU SCREWED UP THE TEST BY NOT DOING IT CORRECTLY AND NEED TO RE-DO IT...
AND DO IT THE RIGHT WAY THIS TIME!!!
Old 09-03-2008, 03:56 PM
  #26
ok yeah then i guess i did two boo boos when i did it man its been way to long since i did
never touched the gas at all and did the plugs one at a time but the 2nd time around i had all 4 plugs out and redid it getting 150psi all the way down so i guess i passed anyways woo whoo!! i rebuilt my motor the right way!
Old 09-03-2008, 03:58 PM
  #27
I see your point but why not just do it the right way.
Some of us would like to know if we are capable of getting an A+ on the big test if we study instead of staying out all night drinking and just getting by with a D.
In other words, I would like to know the actual numbers my rig is capable of.
Old 09-03-2008, 04:01 PM
  #28
I hear ya toyota-erik, but sometimes haste is the soup d'jour.
Old 09-03-2008, 04:06 PM
  #29
yeah im going to be redoing it again when i do the plugs i knew i should have got new ones when i rebuild the motor anyways when i do them i will be buying a new gauge and testing it again wot and all plugs out this time lol soon to be doing this i hope anyways lol
Old 09-03-2008, 04:07 PM
  #30
Touche`
Old 09-03-2008, 04:26 PM
  #31
ozziesironmanoffroad's Avatar
just checked mine... 173ish all 4 cylinders... woo hoo for 22re.. man those japanese guys really know how to make engines
Old 09-03-2008, 04:33 PM
  #32
nick i hate you you have more psi but mine is way faster then yours i dont get it ha ha that was a fun race i cant believe i drove 2000 miles for a simple street race lol
Old 09-03-2008, 06:56 PM
  #33
i have more psi... and more miles teehee
Old 09-03-2008, 07:44 PM
  #34
and probably more door too.
Old 09-06-2008, 10:01 AM
  #35
more door?
and allan, why are you rebuilding the motor again? isnt it pretty much freshly rebuilt?
Old 09-06-2008, 10:28 AM
  #36
more door? ...
he chopped his doors to make half's.
Blamalam
03-12-2022 07:34 AM
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Sidherish
08-02-2015 01:42 PM
Quick Reply: did a compression test today and guess what....
